Tesla Model S GEN1 Charger
Connectors
Charger Connections
Logic Connector X042
The Logic Connector X042 needed to plug into the charger is Molex 194180026[3] which is in the MX150L series.
Pin No. | Function | Description |
1 | 12v supply | |
2 | Charge Port: nozzle lock | "InsertEN out" |
3 | HVIL Out | |
4 | CAN + | |
5 | EVSE-Pilot (CP) | |
6 | FC CAN (SWCAN?) | |
7 | 12v GND | |
8 | Drive inhibit | "Prox out", signal to DU to inhibit drive |
9 | HVIL In | |
10 | CAN - | |
11 | EVSE-Prox (PP) | |
12 | "BMS_12V_in" | (BMS enables charger?) |
AC (Input) Connector Xnnn
DC (Output) Connector Xnnn
Unknown Connector Xnnn
Common Issues
- The Tesla chargers are very sensitive to grounding. The case MUST be connected to vehicle 12v ground and EVSE earth/ground when charging. [1] The OEM installation has a prominent ground strap.
Charger Dimensions: TBD
Tesla Part Numbers (TPN)
- 6009278-00-x
