The LIM is also available new from BMW spare parts suppliers for € 240. If you get it new, it comes without firmware loaded, and it must be programmed first.
External links
> CAN logs
Connectors and Pinouts
1B | 16 Pin Connector | Hirschmann 805-587-545[2] |
Audi 7M0 973 119 |
X | Replacement Pins | 5-962885-1[5] |
X | Rubber Seal | 1-967067-1[6] |
X | (for the connector on the i3's Charge Port Cable Lock, |
1B-1 | LED_S | Charge Port Lighting (not necessary) |
1B-2 | - | |
1B-3 | LED_M | Charge Port Lighting (not necessary) |
1B-4 | LOCK_MOT+ | Charge Port cable Lock Motor |
1B-5 | LOCK_MOT- | Charge Port cable Lock Motor, and reference for 1B-16. |
1B-8 | IGN | Wake up signal input and output +12V (ignition, contact 15) |
1B-10 | PE / GND | Ground |
1B-11 | - | |
1B-12 | - | |
1B-13 | - | |
1B-14 | - | |
1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
1B-16 | LOCK_FB | Charge Port cable Lock Feedback (1k unlocked, 11k locked), referenced to 1B-5[7]. |
Pin # | Function | Description (BMW) | Description (MINI)[8] |
2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! | Pilot (charge port) |
2B-2 | PP | Proximity (charge port) | Proximity (charge port) |
2B-3 | Jumper | Connected to Pin 4 | GND |
2B-4 | Jumper | Connected to Pin 3 | Connected to Pin 5 |
2B-5 | GND | Ground (charge port) | Connected to Pin 4 |
2B-6 | US CCS1 version connected to 2B-2 | N/C (TBD if used for US CCS1) |
3B Pinout:
- N/A (for CHAdeMO only)
4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance must be ~15 ohms) |
4B-2 | NEG_CONT+ | Negative HV Contactor Control (Contactor coil resistance must be ~15 ohms) |
4B-3 | POS_CONT- | Positive HV Contactor Control (Contactor coil resistance must be ~15 ohms) |
4B-4 | NEG_CONT- | Negative HV Contactor Control (Contactor coil resistance must be ~15 ohms) |
4B-5 | U_HV_DC | Charge Port DC Voltage (current input 3-20mA?)(1.42V for 0V HV, linear to 4.8V for 500V HV)[9] |
4B-6 | LED_RT | Red charge Status Light (12V RGB LED) |
4B-7 | LED_GN | Green charge Status Light (12V RGB LED) |
4B-8 | LED_BL | Blue charge Status Light (12V RGB LED) |
4B-9 | LED_GND | Charge Status Light Ground (common cathode of RGB LED) |
4B-10 | COV_MOT- | Charge Port Cover Motor (Not necessary) |
4B-11 | COV_MOT+ | Charge Port Cover Motor (Not necessary) |
4B-12 | COV_FB | Charge Port Cover Feedback (connect to GND to simulate open cover[10])(To be left floating for contactors weld test) |
Wiring Diagram
Wiring notes
This board needs to produce an isolated 3-20mA current signal (or: 1.42V for 0V HV, linear to 4.8V for 500V HV)[12] from the high voltage DC voltage.
Fast charge contactor
Larger contactor control
Charge port
Make sure to match these if you want to use a different charge port. Some brands use different resistance values.
Charge port lock
- Connector shell: BMW 12527549033[13] or Hirschmann 805122541[14]
- Terminals: BMW 61131393724
RGB charge indication light
Wake/sleep
- On plug insertion.
Programming a new LIM
If you order a new LIM there is no configuration loaded but our hero Damien managed to program a brand new LIM with a i3 BDC (Body Domain Controller).
https://openinverter.org/forum/viewtopic.php?p=43848#p43848
- Software:
- Hardware:
- Car key from the same car as the BDC. EDIT: this may not be necessary as the BDC can be put into "on" mode by running the full fault delete function using ISTA [15]
Charge control
Contactor Test
- Fault set in 0x272 byte 2
CCS inlet temperature sensors
CAN communication
ID | Function | sent by | interval | Notes |
0x112 | BMS msg. | VCU or BMS | 10ms | needed |
0x12F | Wake up | VCU | 100ms | needed |
0x3E9 | Main LIM control | VCU | 200ms | needed |
0x2F1 | Lim DC charge command 2. | VCU | 100ms | needed |
0x2FA | Lim DC charge command 3. | VCU | 80ms...1s | needed (low interval during CCS start up) |
0x2FC | Charge flap control | VCU | 100ms (4s) | needed (constant values work) |
0x431 | Battery info | VCU | 200ms | needed but does not control anything |
0x432 | BMS SoC | VCU or BMS | 200ms | display SoC needed |
0x03C | Vehicle status | VCU | 200ms | (constant values) |
0x1A1 | Vehicle speed | VCU | 20ms | (constant values) |
0x2A0 | Central locking | VCU | 200ms (4s) | (constant values) |
0x3F9 | Engine info | VCU | 1000ms | (constant values) |
0x3A0 | Vehicle condition | VCU | 200ms | (constant values) |
0x51A | Network management | VCU | 200ms | (constant values) needed? |
0x540 | Network management 2 | VCU | 200ms | (constant values) needed? |
0x510 | Network management zgw | VCU | 200ms | (constant values) needed? |
0x328 | Counter | VCU | 1s | needed |
0x3E8 | OBD reset | VCU | 1s | (constant values) |
Messages sent by LIM | ||||
0x29E | CCS charger specs | LIM | ||
0x2EF | Min. available voltage from the CCS charger. | LIM | ||
0x2B2 | Current and Voltage as measured by the CCS charger | LIM | ||
0x3B4 | EVSE info: CP, PP & inlet voltage | LIM | ||
0x272 | CCS contactor state and charge flap open/close status. | LIM | ||
0x337 | Inlet lock status | LIM |
LIM logs
Observations
LIM hardware
Physical dimensions
LIM versions
Part No. | IEC 61851
J1772 (AC) |
61 35 9 380 352 | x | x | ? | BMW i3 | Nov 2015 | ||
61 35 6 828 052 | BMW i3 | Aug 2019[16] | |||||
61 35 9 494 498 | x | x | ? | BMW i3 | 2018? | x | |
61 35 9 470 199 | x | x | ? | BMW i3 | ? | ||
Mini cooper SE |
now |
Power Limits
Chips on the LIM board
Chip | Description | Function | Datasheet |
Renesas V850E2/FG4 | 32-bit Single-Chip Microcontroller | main MCU | https://www.renesas.com/us/en/document/dst/data-sheet-v850e2fg4 |
Qualcomm QCA7000 | HomePlug® Green PHY, single chip solution | PLC Green PHY | https://openinverter.org/forum/download/file.php?id=9611 |
Infineon TLE 7263E | Integrated HS-CAN, LIN, LDO and HS Switch, System Basis Chip | CAN, 2xLDO, wake-up | https://docs.rs-online.com/db13/0900766b814d680b.pdf |
TI SN74LVC2T45-Q1 | Dual-Bit Dual Supply Transceiver with Configurable Voltage Translation | https://www.ti.com/lit/gpn/sn74lvc2t45-q1 | |
NXP 74LVC1T45 | Dual supply translating transceiver | https://datasheetspdf.com/pdf-file/648034/NXP/74LVC1T45/1 | |
STM L9951XP | Actuator driver | inlet lock motor | https://www.st.com/resource/en/datasheet/l9951.pdf |
STM TS321 | Low-Power Single Operational Amplifier | https://www.ti.com/lit/gpn/ts321 | |
TI LM2902 | Quadruple general-purpose operational amplifier | https://www.ti.com/lit/gpn/lm2902 | |
STM VNQ5E250AJ-E | Quad channel high-side driver with analog current sense | LEDs?, contactors? | https://www.st.com/resource/en/datasheet/vnq5e250aj-e.pdf |
Charging protocols
Signaling circuit
AC charging
CCS DC charging
