Batteries
Revision as of 11:06, 6 June 2023 by Marcexec (talk | contribs) (→‎OEM modules: added LFP Tesla modules)
Battery pack specification
Capacity (kWh)
Voltage (V)
Maximum current (A)
Mass (kg)
Volume (L)
Cell chemistry
LiFePO4 pouch cells
General build requirements
Compression
*placeholder*
LiFePO4 prismatic cells
*placeholder*
LiFePO4 cylindrical cells
*placeholder*
LiFePO4 cell ageing
Lithium-ion
  • Overcharging
Li-ion pouch cells
OEM modules
Manufacturer Model Capacity (kWh) Weight (kg) w (mm) d (mm) h (mm) Gravity (kg/kWh) Volume (L/kWh) Voltage (V) Current (cont A) Current (peak A) Cell arrangement Cell type Chemistry
Tesla Model S 85kWh 5.3 26 690 315 80 4.9 3.3 22.8 500 750 74p6s 18650 Li-ion
Tesla Model S 100kWh 6.4 28 680 315 80 4.4 2.7 22.8 870 86p6s 18650 Li-ion
Tesla Model 3 LR (inner) 19.2 98.9 1854 292 90 5.2 2.5 91.1 971 46p25s 2170 Li-ion
Tesla Model 3 LR (outer) 17.7 86.6 1715 292 90 4.9 2.5 83.9 971 46p23s 2170 Li-ion
Tesla Model 3 SR (inner) 13.0 58.9 1385 326 90 3.7 91.1 603 31p24s 2170 Li-ion
Tesla Model 3 SR (outer) 12.0 58.9 1380 344 90 3.8 83.9 603 31p24s 2170 Li-ion
Tesla Model 3 LFP (inner) 13.38 86 1860 323 81 6.4 83 161 23s Prismatic LiFePo4
Tesla Model 3 LFP (outer) 15.07 93.48 1948 323 81 6.2 93.5 161 25s Prismatic LiFePo4
Calb 4S3P 2.19 12 355 151 108 5.5 2.6 14.6 900 3p4s Pouch Li-ion
Calb 6S2P 2.19 12 355 151 108 5.5 2.6 22.2 600 2p6s Pouch Li-ion
Chevrolet Volt 2012 4 38 470 180 280 9.5 5.9 88.8 676 3p24s Pouch Li-ion
BMW i3 60Ah 2 13 410 310 150 6.5 9.5 28.8 210 350 2p8s Prismatic Li-ion
BMW i3 94Ah 4.15 28 410 310 150 6.7 4.6 45.6 409 12s Prismatic Li-ion
BMW i3 120Ah 5.3 28 410 310 150 5.3 3.6 45.6 360 12s Prismatic Li-ion
BMW PHEV 34Ah 2.0 13.05 368 178 102 6.525 3.34 59.0 Prismatic Li-ion
Jaguar iPace 2.5 12 340 155 112 4.8 2.4 10.8 720 1200 4p3s Pouch Li-ion
LG 4P3S 2.6 12.8 357 151 110 4.9 2.3 11 4p3s Pouch Li-ion
Nissan Leaf 24kWh 0.5 3.65 300 222 34 7.3 4.5 7.2 130 228 2p2s Pouch Li-ion LMO
Nissan Leaf 30kWh 1.25 300 222 34 3.6 14.4 2p4s Pouch Li-ion
Nissan Leaf 40kWh 1.6 8.7 300 222 68 5.4 2.8 14.4 314 2p4s Pouch Li-ion NMC
Nissan Leaf 62kWh 2.58 14.4 3p4s Li-ion
PSA/Opel Pugeot E-208, Corsa E 2.73 12.7 390 150 115 4.6 2.5 21.9 6p2s Prismatic Li-ion
VW Passet GTE 2.48 23.4 (with cooler plate)
10.8kg single
410 (C/P)
355 (S)
235 (C/P)
150 (S)
150 (C/P)
108 (S)
VW Golf GTE 1.086 9.8 355 152 110 9.02 5.5 44 12s Prismatic Li-ion
VW Touareg 14,1 kWh 1.76 12.3 385 150 108 7.0 3.5 45.25 13s Prismatic Li-ion
VW id3/id4 55kWh, 62kWh 6.85 32 225 590 110 4.67 2.13 44.4 12s2p
VW id3/id4 82kWh 6.85 32 225 590 110 4.67 2.13 29.6 8s3p
Toyota Prius Prime 1.76 16.9 597 152 121 9.6 6.24 70.3
