Tesla Model S GEN1 Rear HVJB
The Tesla Model S GEN1 Rear HVJB (TPN 1016561-00-A) was a High Voltage Junction Box found in the all 2012 through late 2013 Model S. It is centrally located under the rear seat frame, and the Single or Dual GEN1 On-board Charger(s) (OBC) are located to the right and left of it. It was replaced via gradual phase-in by the GEN2 Rear HVJB starting around Oct2013, when the GEN2 On-board Chargers were introduced; the GEN1 & GEN2 Rear HVJBs are not interchangeable, neither physically nor electrically.
- Traction Battery Pack (HV DC)
- Drive Unit ("Inverter") (rear only, as the Dual Motor option wasn't offered during the GEN1's lifespan)
- Charge Port (AC and DC input)
- DC-DC Converter (GEN1, which also functioned as the Front HVJB)
- On-Board Charger(s) (GEN1 Chargers only)
HV
All HV connections are well documented by the "Theory of Operation" image below. All are bolted connections.
LV
Depending upon whether Single or Dual OBCs are installed, either (1), or (5), of the LV connectors will not be in use. Extra/unused internal harnessed connectors have "parking" places to stow unused connectors. The various LV connectors are detailed below.
Logic "dummy" connector
This is a panel-mount Molex MX150L Panel-Mount PCB 19428-0001 plug. For installations where there is only a Single OBC installed, it provides a place to "park" the unused harness WWMA2 that would normally be connected to a Second/Slave OBC.
It has a small PCB soldered to its rear, which contains ONLY (3) 180 ohm resistors, wired in parallel, to provide a net 60 ohm path for the HVIL Loop, on pins 3 & 9. See HVIL section for details on how this connector is used.
HVIL
The HVIL Loop
Like other HV assemblies on the Model S, the Rear HVJB has a Lid Reed Switch, activated by a magnet on the cover, that breaks the HVIL Loop when the cover is removed. The Rear HVJB has a short harness from this Lid Reed Switch, which is always plugged into the Single or Master OBC to maintain the HVIL Loop.
HVIL Lid Reed Switch
HVIL Loopback Harness
Fast Charge Contactors Control
- These four-pin connectors each route to a single contactor in the Rear HVJB. Those contactors bypass AC charging and allow DC from the Charge Port to connect directly to the HV bus for DCFC.
- These two connectors are physically interchangeable.
- One has a red plastic connector, and connects to the B+ contactor.
- One has a white plastic connector, and connects to the B- contactor.
- The top row pins are 12v; the bottom row pins are Auxiliary contacts, NO (normally open). These harness' black wires are for the contactors' coils, and the white wires are for the NO auxiliary contacts.
AC Input Connector
DC Output Connector
GEN1 Rear HVJB Dimensions:
- Weight: nn lbs (nn kg)
- ↑ https://static.nhtsa.gov/odi/tsbs/2014/SB-10052449-4313.pdf Pg. 1
- ↑ https://static.nhtsa.gov/odi/tsbs/2014/SB-10052449-4313.pdf Pg. 10
