Tesla Model S GEN1 Rear HVJB
The Tesla Model S GEN1 Rear HVJB (TPN 1016561-00-A) was a High Voltage Junction Box found in the all 2012 through late 2013 Model S. It is centrally located under the rear seat frame, and the Single or Dual GEN1 On-board Charger(s) (OBC) are located to the right and left of it. It was replaced via gradual phase-in by the GEN2 Rear HVJB starting around Oct2013, when the GEN2 On-board Chargers were introduced; the GEN1 & GEN2 Rear HVJBs are not interchangeable, neither physically nor electrically.
  • Traction Battery Pack (HV DC)
  • Drive Unit ("Inverter") (rear only, as the Dual Motor option wasn't offered during the GEN1's lifespan)
  • Charge Port (AC and DC input)
  • DC-DC Converter (GEN1, which also functioned as the Front HVJB)
  • On-Board Charger(s) (GEN1 Chargers only)
Tesla Model S Rear HVJB, cover removed.
HV
All HV connections are well documented by the "Theory of Operation" image below. All are bolted connections.
Tesla Model S GEN1 Rear HVJB component details, from Tesla Service Manual, "Theory of Operation" section.
LV
Depending upon whether Single or Dual OBCs are installed, either (1), or (5), of the LV connectors will not be in use. Extra/unused internal harnessed connectors have "parking" places to stow unused connectors. The various LV connectors are detailed below.
Logic "dummy" Connector
This is a panel-mount Molex MX150L Panel-Mount PCB 19428-0001 plug. For installations where there is only a Single OBC installed, it provides a place to "park" the unused harness WWMA2 that would normally be connected to a Second/Slave OBC.
Tesla Model S OBC in Single/Master configuration. Note "parked" harness WWMA2 on Rear HVJB.
It has a small PCB soldered to its rear, which contains ONLY (3) 180 ohm resistors, wired in parallel, to provide a net 60 ohm path for the HVIL Loop, on pins 3 & 9. See HVIL section for details on how this connector is used.
Telsa Model S GEN1 Rear HVJB: harness WWMA2 "parking" connector which contains only a 60 ohm resistor. This connector is used when a Tesla does not have a Second/Slave OBC.
Telsa Model S GEN1 Rear HVJB: front view of harness WWMA2 "parking" connector which contains only a 60 ohm resistor.  This connector is used when a Tesla does not have a Second/Slave OBC.
Telsa Model S GEN1 Rear HVJB: rear views of harness WWMA2 "parking" connector which contains only a 60 ohm resistor.  This connector is used when a Tesla does not have a Second/Slave OBC.
Telsa Model S GEN1 Rear HVJB: rear view of harness WWMA2 "parking" connector which contains only a 60 ohm net resistance.  This connector is used when a Tesla does not have a Second/Slave OBC.
Tesla Model S GEN1 Rear HVJB "parking" connector for harness WWMA2, used in Single OBC installations only. Note (3) 180 ohm resistors, connected in parallel, to obtain net 60 ohms for HVIL loop.
180 ohm resistor. One of three on the Tesla Model S GEN1 Rear HVJB "parking" connector for harness WWMA2, which is used only in Single OBC installations.
HVIL
The HVIL Loop
Like other HV assemblies on the Model S, the Rear HVJB has a Lid Reed Switch, activated by a magnet on the cover, that breaks the HVIL Loop when the cover is removed. The Rear HVJB has a short harness from this Lid Reed Switch, which is always plugged into the Single or Master OBC to maintain the HVIL Loop.
HVIL Lid Reed Switch
Tesla Model S GEN1 HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
Tesla Model S GEN1 Rear HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
Closeup of Tesla Model S GEN1 HVJB (under rear seat), lid removed, showing the HVIL cover reed switch and HVIL connector that connects to a mating connector on the OBC.
Tesla Model S GEN1 HVIL circuit overview, from Tesla Service Bulletin SB-10052449-4313, pg. 1.
Tesla Model S GEN1 HVIL circuit overview, from Tesla Service Bulletin SB-10052449-4313, pg. 7.
Tesla Model S GEN1 HVIL circuit overview, from Tesla Service Bulletin SB-10052449-4313, pg. 8.
HVIL Loopback Harness
  • Tesla: The loopback harness, Tesla 1101371-00-A, is included/stored inside all Tesla Model S GEN1 Rear HVJB in an internal "parking" socket, when only a single OBC is provisioned. See Other Parked Connectors below.
Fast Charge Contactors Control
Tesla Model S Rear HVJB: Single/Master OBC interface connectors. All (5) of these are in use for the Single/Master OBC; only the AC and DC connectors are in use for a Second/Slave OBC (no HVIL or Fast Charge Connectors are used for the Second/Slave OBC).
Tesla Model S GEN1 OBC Connectors, to which the GEN1 Rear HVJB's side harnesses mate.
Tesla Model S GEN1 OBC Connectors (closeup of the Fast Charge Contactors Control and HVIL) to which the GEN1 Rear HVJB's side harnesses mate.
  • These four-pin connectors each route to a single contactor in the Rear HVJB. Those contactors bypass AC charging and allow DC from the Charge Port to connect directly to the HV bus for DCFC.
  • These two connectors are physically interchangeable.
    • One has a red plastic connector, and connects to the B+ contactor.
    • One has a white plastic connector, and connects to the B- contactor.
  • The top row pins are 12v; the bottom row pins are Auxiliary contacts, NO (normally open). These harness' black wires are for the contactors' coils, and the white wires are for the NO auxiliary contacts.
AC Input Connector
DC Output Connector
Other Parked connectors
When a Model S is configured for Single OBC, several connectors that are not used are "parked" and can be used for installing a Second/Slave OBC later. Aside from the Logic "dummy" Connector covered above, there are three more parked connectors, all of which are parked inside the HVJB, left side, behind a blanking plate. These parked connectors are:
  • AC Input (to Second/Slave OBC)
  • DC Output (from Second/Slave OBC)
  • HVIL loopback harness (for installation on Second/Slave OBC)
  • Dimensions:
    • Main "box" area: 12-1/4"L x 7-5/8"W (if cable "spigots" were cut off)/9"W (w/spigots) x 6-1/2"H (311mmL x 194mm/229mmW x 156mmH)
    • Overall w/mounting "arms": 17-1/4"L (438mmL)
  • Weight: 10.2 lbs (4.6 kg) (without cables or bolts for cables; with cover)
