VAG MLBevo MQB Chargers
MEB Chargers
There are many different variants of MQB and MEB chargers with a wide range of potential power outputs.
Part Number Version Power Rating Phase Vehicle Usage Coolant Connections Dimensions Comments Reverse Engineered
5QE915685 3.6kW Single
5QE915685C OBCTYPP036G26V01 3.6kW Single SEAT/CUPRA Leon/Formentor Hybrid Bottom
5QE915682 3.6kW Single
5QE915682AA
5QE915682AF
04S, 13S 3.6kW Single VW Golf MK7 GTE
Audi A3 8V 2018-2020
Bottom Case not welded, 2 HV pass throughs
5QE915682AG 07S 3.6kW Single Audi A3 8V e-tron Bottom
5QE915682AK 03S 3.6kW Single VW Golf MK7 GTE Bottom Yes
5QE915682M OBC C0 3.6kW Single VW Passat Hybrid Bottom
5QE915681AT OBC 7200W 7.2kW Single Audi Q7 e-tron 4M GTE Bottom Case not welded
5QE915681BP OBCTypP072G30V02 7.2kW Dual VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba Left side Made by Delta, HV pass through
5QE915681BQ OBCTypP072G30V03 7.2kW Dual Porsche Cayenne Hybrid 2017-2021 Left side
5QE915681CQ OBCTypP072G30V03 7.2kW Dual Audi A8 PHEV 2022 Left side No HV pass through.
5QE915681B OBC 7200W 7.2kW Dual VW e-Golf 2017-2022 Bottom Case not welded
5QE915681D OBC 7200W 7.2kW Dual Audi Q5 PHEV 2020-2021 Right side Case not welded, no HV pass through
5QE915681N OBC 7200W 7.2kW Dual VW e-Crafter Bottom Case not welded
5QE915684A 11kW Three Audi e-tron Opposite End of Electrical
5QE915684AD
5QE915684AT
5QE915684J
OBCTYPP110G10V01 11kW Three Audi e-tron
Audi e-tron Sportback 2019-2021
Opposite End of Electrical 300 x 200 x 100 mm Made by KOSTAL
Taredown can be purchased here
5QE915684AL
5QE915684BG
5QE915684BK
5QE915684CB
5QE915684CR
OBCTYPP110G10V03 11kW Three Porsche Taycan
Audi e-tron GT
Right Side Made by KOSTAL
Dual AC inputs
5QE915684BJ OBCTYPP110G10V04 11kW Three Audi e-tron(?) Right Side Made by KOSTAL
5QE915684BC
5QE915684CM
OBCTYPP110G10V05 11kW Three Audi e-tron Opposite End of Electrical Made by KOSTAL
9J1915681AD
9J1915681AH
OBC 22kW C3 ROW 22kW Three Porsche Taycan 2019 Right Side 498 x 235 x 100 mm Longer case than other models.
Made by Meta System in Italy
Taredown available here
1EA915684AD
1EA915684AF
1EA915684BF
1EA915684BG
OBCTYPP110G040V04K 11kW Three Audi Q4 e-tron 2021
Skoda Enyaq 2020
VW ID.3 2020
VW ID.4 2021
AC input end 480 x 313 x 102 mm Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic.
Made by KOSTAL
Pinouts
Pinouts of 60 Pin Connector (Part Number 5Q0906379[1])
VW Golf PHEV Seat Mii / VW e-Golf[2]
Pin Function Comment Function Comment
1 Terminal 30 (permanent 12V) Terminal 30
2
3
4 Charge Port RGB LED +12v o/p
5 Charge Port RGB LED +12v o/p
6
7
8
9 Powertrain CAN bus, high Powertrain CAN bus, high
10 Powertrain CAN bus, low Powertrain CAN bus, low
11 Hybrid CAN bus, high Hybrid CAN bus, high
12 Hybrid CAN bus, low Hybrid CAN bus, low
13 HVIL IN HVIL IN
14
15 HVIL OUT HVIL OUT
16 Lock drive +. Drive to 12v to close lock.
17 Lock Drive – Drive to 12v to open lock
18 Lock feedback. 1K fully locked ur unlocked. 11K in travel.
19 Lock feedback. 1K fully locked ur unlocked. 11K in travel.
20
21 Immediate charge buttons
22 Charge Port RGB LED +12v o/p
23 Control Pilot (CP)
24 Plug Present (PP)
25 Immediate charge buttons
26
27 Temperature sender for charging socket. 1067R at approx 15C
28 Temperature sender for charging socket. 1067R at approx 15C
29
30
31 Charge port door lock actuator
32 Charge port door lock actuator
33 Charge port door lock actuator
34 Charge port door lock actuator
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51 Immediate charge buttons
52
53
54
55
56
57
58
59
60 Terminal 31 (Ground) Terminal 31
AC Connection
Golf GTE - Part number TE Connectivity 2103177-2
