BMW i3 Inverter
Revision as of 13:19, 4 November 2023 by CJW (talk | contribs) (Added motor sensor pinout for ERNI Minibridge connector)
BMW I3 inverter
BMW I3 inverter
Pinout for Ampseal Plug
Pin No Assigniment Description
1 12V
2 BRAKE_IN
3 PRECHARGE_OUT
4 CANL
5 CANH
6 DCSW_OUT
7 FORWARD_IN
8 REVERSE_IN
9 5V (OUT)
10 RESOLVER_S2/ENCODER_A Sin Low (blue)
11 GND
12 RESOLVER_S1 Sin Hi (red)
13 THROTTLE1
14 THROTTLE2
15 RESOLVER_R1 Excitation Hi (yellow)
16 RESOLVER_S3/ENCODER_B Cos Hi (white)
17 MTEMP+ (blue)
18 MTEMP- (grey)
19 RESOLVER_S4 Cos Low (brown)
20 EMCYSTOP_IN
21 GND
22 RESOLVER_R2 Excitation Low (green)
23 START_IN
Note: colours in description column above are currently unconfirmed and for the BMW cables coming from the motor.
There are 2 variants of the i3. one with the REX and one with out.
the REX variant has a additional 25kw inverter to run the onboard generator.
Gate Driver Board Pin out
Pin No I/O Description Notes Pin No I/O Description Notes
1 21 GND Switching Mosfets ?
2 I 32V in 22 GND Switching Mosfets ?
3 I 32V in 23
4 I IGBT A HI 24
5 I IGBT A LOW 25
6 I CS (ADC) 26 GND IGBT Driver ground
7 I SDI 27 GND IGBT Driver ground
8 I SDO 28 GND IGBT Driver ground
9 I SCK 29 GND IGBT Driver ground
10 I IGBT B HI 30 GND IGBT Driver ground
11 I IGBT B LOW 31 GND IGBT Driver ground
12 I IGBT C HI 32 GND IGBT Driver ground
13 I IGBT C LOW 33 5V IGBT Driver Power
14 34 5V IGBT Driver Power
15 35 I IGBT PSU 12V on
16 O IGBT DRIVER UVW Upper Ready 36 O IGBT Driver Fault
17 O IGBT DRIVER UVW Lower Ready 37 I 5V LEM Current sensor Power
18 O Current Sense C Signal 38 GND Current sensor Ground
19 O Current Sense B Signal 39 GND Current sensor Ground
20 O Current Sense A Signal 40 GND Current sensor Ground
Motor Resolver & Temperature Sensors
12-pin PCB header to connect to the motor sensors is an ERNI MiniBridge, part number 294920
Wire colours to pin allocation below confirmed by multimeter trace. Resolver coils confirmed by resistance, however sin vs cos and hi vs lo are not confirmed yet, provisional info below in italics, based on forum posts.
ERNI Minibridge Connector. Dots indicate pin 1.
Pin No Colour Description Notes
1 Brown Sin Hi Twisted pair. 22.4 - 33.6 Ω.
2 Blue Sin Lo
3 Yellow Ex Hi Twisted pair. 22.4 - 33.6 Ω
4 Green Ex Lo
5 Red Cos Hi Twisted pair. 13.6 - 20.4 Ω
6 White Cos Lo
7 Blue From BMW Service Technical Training Manual - I01 High-voltage Components:
There are two stator coil temperature sensors. The rotor temperature is determined using readings from the stator temperature sensors.
8 Grey
9 Red
10 Grey
11 - Unused These wires terminate in one of the six pin connectors in
the motor housing. There is nothing connected to them.
12 - Unused
