CAD Models
This section has been added to allow people to post external links to existing CAD models that are freely available and are broken up by subcategory. Many models are already available, however if you can't find an existing model, there is a section at the end labelled Requests where members can login and simply add a line to this section with a short description of the component they would like.
Please note: all models should include an external link with an acknowledgement to the host and original creator.
Batteries
Manufacturer | Model | Host Site | Author/Creator | Link |
LG Chem | 4p3s Module | Zero EV | Chris Hazell | https://zero-ev.co.uk/cad/ |
CALB | 3p4s Module | Zero EV | Chris Hazell | https://zero-ev.co.uk/cad/ |
Nissan | Leaf Gen 1 Cell | GrabCAD | Brock Winberg | https://grabcad.com/ |
Nissan | Leaf 24 kWh pack | GrabCAD | Kevin Kuehn | https://grabcad.com/ |
Tesla | Model S/X 5.3kWh Battery Module | Openinverter Forum | https://openinverter.org/forum/ | |
Tesla | Model 3 Passenger side inboard battery module | Openinverter Forum | https://openinverter.org/forum/ | |
Tesla | Model 3 Passenger side outboard battery module | Openinverter Forum | https://openinverter.org/forum/ | |
Tesla | Model 3 Driver side inboard battery module | Openinverter Forum | https://openinverter.org/forum/ | |
Tesla | Model 3 Driver side outboard battery module | Openinverter Forum | https://openinverter.org/forum/ | |
Tesla | Full Model S Battery Pack | GrabCAD | saurabh dhuri | https://grabcad.com/ |
Mitsubishi | Outlander Yuasa 8 cell module | GrabCAD | https://grabcad.com/ | |
VW | GTE Golf/Pasaat 2x12s module with plate | GrabCAD | TomdB | https://grabcad.com/ |
Inverters
Nissan | Leaf Gen 2 Drive Unit | GrabCAD | Paul Baque | https://grabcad.com/ |
Nissan | Leaf Gen 2 (EM57) | GrabCAD | James Harris | https://grabcad.com |
Nissan | Leaf Gen 1 Inverter | GrabCAD | coming soon | |
Toyota | Yaris (Gen 3) Inverter | GrabCAD | coming soon | |
Toyota | Prius (Gen 3) Inverter | GrabCAD | https://grabcad.com/ | |
Toyota | Prius (Gen 2) Inverter | GrabCAD | coming soon | |
Lexus | GS-450H Inverter phone scan | GrabCAD | https://grabcad.com/ | |
Lexus | GS-450H Inverter scan | GrabCAD | TomdB | https://grabcad.com/ |
Lexus | IS-300H Inverter | GrabCAD | TomdB | https://grabcad.com/l |
Mitsubishi | Outlander Rear | GrabCAD | TomdB | https://grabcad.com/ |
Motors
Lexus | GS-450H | GrabCAD | coming soon | |
Nissan | Leaf Gen 1 (EM61) with gearbox | GrabCAD | coming soon | |
Nissan | Leaf Gen 2 (EM57) | GrabCAD | Julius Wächter | https://grabcad.com |
Toyota | Prius Gen 3 Transaxle | GrabCAD | coming soon | |
Toyota | Prius Gen 2 Transaxle | GrabCAD | coming soon | |
Toyota | MGR | GrabCAD | TomdB | https://grabcad.com/ |
Lexus | GS450h Gearbox | GrabCAD | TomdB | https://grabcad.com/ |
Drive Units (motor/gearbox/inverter)
Nissan | Leaf Gen 2 (EM57) | GrabCAD | James Harris | https://grabcad.com/library/nissan-leaf-em57-motor-inverter-pdu-gearbox-1 |
Tesla | Model S/X SFDU | GrabCAD | Brock Winberg | https://grabcad.com/library/tesla-front-small-drive-unit-3d-scan-1 |
Tesla | Model S/X SRDU | GrabCAD | James Warner | https://grabcad.com/library/tesla-rear-small-drive-unit-3d-scan-1 |
Tesla | Model S/X LDU | GrabCAD | Winston Jennings | https://grabcad.com/library/tesla-rear-drive-unit-1 |
Tesla | Model S/X LDU with subframe | GrabCAD | joe k | https://grabcad.com/library/tesla-model-s-large-drive-unit-1 |
Tesla | Model 3/Y RDU | GrabCAD | Zero EV | https://zero-ev.co.uk/cad/ |
Tesla | Model 3/Y RDU with subrframe | GrabCAD | Matt Brown | https://grabcad.com/library/tesla-model-3-rear-subframe-and-motor-1 |
Misubushi | PHEV Rear Drive Unit | GrabCAD | Volt Influx | https://grabcad.com/library/outlander-phev-rear-motor-1 and https://grabcad.com/library/outlander-phev-rear-gearbox-1 |
Chargers
Mitsubishi | Outlander | GrabCAD | TomdB | https://grabcad.com/ |
Nissan | Leaf Gen 1 | GrabCAD | coming soon | |
Tesla | Model S Gen 2 | Openinverter Forum | https://openinverter.org/forum/ | |
Tesla | PCS | GrabCAD | Wim Boone | https://grabcad.com/ |
Gearboxes
Mitsubishi | Outlander Rear | GrabCAD | TomdB | https://grabcad.com |
Nissan | Leaf | GrabCAD | James Harris | https://grabcad.com |
HV Components
AC Compressor | Nissan | GrabCAD | James Harris | https://grabcad.com |
Mitsubishi | Outlander Water Heater | GrabCAD | TomdB | https://grabcad.com/ |
Mitsubishi | Outlander AC Compressor | GrabCAD | TomdB | https://grabcad.com/ |
VW | Egolf/GTE Heater | GrabCAD | TomdB | https://grabcad.com/ |
VW | Egolf/GTE AC Compressor | GrabCAD | TomdB | https://grabcad.com/ |
VW | IDx Air PTC | GrabCAD | TomdB | https://grabcad.com/ |
Miscellaneous
Type | Manufacturer | Model | Host Site | Author/Creator | Link |
Current Shunt | Tesla | P85 | GrabCAD | https://grabcad.com/library/1430339 | |
Current Shunt | ISA | IVT-S 500 | GrabCAD | TomdB | https://grabcad.com/ |
Current Shunt | ISA | IVT-S 1K | GrabCAD | TomdB | https://grabcad.com/ |
Coolant Valve | Tesla | Model S/X 3way Valve | GrabCAD | TomdB | https://grabcad.com/ |
Coolant Pump | BMW | 5 Series Pierburg | GrabCAD | TomdB | https://grabcad.com/ |
Power steer pump | TRW | From Opel Astra | GrabCad | J0hannes | Link |
BMW i3 LIM | BMW | I3 | GrabCad | Wim Boone | https://grabcad.com/ |
HV DC Contactor | Tesla | Model 3/Y | GrabCad | Wim Boone | https://grabcad.com/ |
CCS Contactor | Tesla | Model 3/Y | GrabCad | Wim Boone | https://grabcad.com/ |
12V Penthouse connector | Tesla | Model 3/Y | GrabCad | Wim Boone | https://grabcad.com/ |
Requests
Please add your requests here for any CAD models or scans that you have been unable to find online or in the tables above. See example below:
Example request: Motor - Nissan - Leaf Gen 1 EM61 (without gearbox)
Note: If anyone is able to take a scan or source an existing model for a request, please add it to the tables above and remove the request from this section. Many thanks.
