VAG PTC Air Heater
Revision as of 16:20, 20 December 2024 by Tom91 (talk | contribs) (Categories)
VW 1EA963581 PTC heater
Overview[1]
PTC heater assembly found in VW ID series (ID.3, ID,4, ID.Buzz, etc.), as well as other VAG EVs (Seat, Skoda, Audi, etc).
  • According to VW, the nominal voltage is 150 to 475V, but findings suggest it’s usable from 180VDC.
  • It is made by Valeo and has a operational range between 0 and 6kW.
Part Numbers
VAG Part Number Vehicles Used it Tested?
1EA963581AQ No
1EA963581BM No
1EA963581BN No
1EA963581C No
1EA963581D Yes
1EA963581F Yes
1EA963581G No
Connectors
VW 1EA963581 PTC heater connections[2]
High-Voltage Connection
TE HVU 280 series
  • Mating housing: 1-2318082-2 (key B)
  • Contacts:
    • TE-NO: 2-968859-3 (WIRE SIZE 4mm²)
    • TE-NO: 2-968857-3 (WIRE SIZE 2.5mm²)
  • Seals:
    • TE-NO: 828985-1 (WIRE SIZE 4mm²)
    • TE-NO: 963292-1 (WIRE SIZE 2.5mm²)
Low-Voltage Connection
VW 1J0 973 723
Potential Equalization
M6x1 lug
Dimensions and 3D Model
3D Model available at GrabCAD: [3]
Control
EVCreate CAN Gateway[1]
DIY with Teensy[4]
Case Studies
Volvo P80 heater core adapter (to be published)
