VAG MLBevo MQB Chargers
There's a generational difference between the 1-2 phase PHEV chargers, and the newer MLBevo type used on the Audi E-Tron, E-Tron GT & Porsche Taycan
Difference between MLBevo/MQB vs. MEB Chargers
MLBevo/MQB Chargers Overview
There are many different variants of MQB and MLBevo chargers with a wide range of potential power outputs.
These charges are not recommended if you are looking for a known working solution.
Part Number | Version | Power Rating | Phase | Vehicle Usage | Coolant Connections | Dimensions | Comments | Reverse Engineered | AC-Plug Connector | Communication Plug Connector | Coolant hose connector |
5QE915685 | 3.6kW | Single | |||||||||
5QE915685C | OBCTYPP036G26V01 | 3.6kW | Single | SEAT/CUPRA Leon/Formentor Hybrid | Bottom | ||||||
5QE915682 | 3.6kW | Single | |||||||||
5QE915682AA
5QE915682AF |
Audi A3 8V 2018-2020 |
5QE915682AG | 07S | 3.6kW | Single | Audi A3 8V e-tron | Bottom | ||||||
5QE915682AK | 03S | 3.6kW | Single | VW Golf MK7 GTE | Bottom | Yes | |||||
5QE915682M | OBC C0 | 3.6kW | Single | VW Passat Hybrid | Bottom | ||||||
5QE915681AT | OBC 7200W | 7.2kW | Single | Audi Q7 e-tron 4M GTE | Bottom | Case not welded | |||||
5QE915681BP | OBCTypP072G30V02 | 7.2kW | Dual | VW e-Up!, SEAT Mii, SKODA Citigo-e iV, Arriba | Left side | Made by Delta, HV pass through | |||||
5QE915681BQ | OBCTypP072G30V03 | 7.2kW | Dual | Porsche Cayenne Hybrid 2017-2021 | Left side | ||||||
5QE915681CQ | OBCTypP072G30V03 | 7.2kW | Dual | Audi A8 PHEV 2022 | Left side | No HV pass through. | |||||
5QE915681B | OBC 7200W | 7.2kW | Dual | VW e-Golf 2017-2022 | Bottom | Case not welded | |||||
5QE915681D | OBC 7200W | 7.2kW | Dual | Audi Q5 PHEV 2020-2021 | Right side | Case not welded, no HV pass through | |||||
5QE915681N | OBC 7200W | 7.2kW | Dual | VW e-Crafter | Bottom | Case not welded | |||||
5QE915684A | 11kW | Three | Audi e-tron | Opposite End of Electrical | |||||||
5QE915684AD
5QE915684AT 5QE915684J |
Audi e-tron Sportback 2019-2021 |
5QE915684AL
Audi e-tron GT |
Right Side | Made by KOSTAL
Normaquick NW12
(unverified) | ||
5QE915684BJ | OBCTYPP110G10V04 | 11kW | Three | Audi e-tron(?) | Right Side | Made by KOSTAL
Normaquick NW12
(unverified) | ||
5QE915684BC
5QE915684CM |
Normaquick NW12
(unverified) | ||
9J1915681AD
9J1915681AH |
Normaquick NW12
(unverified) | |
1EA915684AD
AC input end | 480 x 313 x 102 mm | Flatter and thinner than most other chargers on this list. Coolant inlets and outlets are plastic, be careful of broken plastic.
LV Connection
VW Golf PHEV | Seat Mii / VW e-Golf[2] | MLBevo (Audi Etron)[3] | ||||
Pin | Function | Comment | Function | Comment | Function | Comment |
1 | Terminal 30 (permanent 12V) | Terminal 30 | Terminal 30 | confirmed | ||
2 | Charging Cover Lock (+) - Socket A | |||||
3 | Switch/LED Common - Socket A | confirmed / Sensor Ground / Both pin 3 and 45 can be tied together | ||||
4 | Charge Port RGB LED +12v o/p | LED - Red - Socket A | ||||
5 | Charge Port RGB LED +12v o/p | LED - Green - Socket A | ||||
6 | LED - Blue - Socket A | |||||
7 | Illumination LED - Socket A | |||||
8 | ||||||
9 | Powertrain CAN bus, high | Powertrain CAN bus, high | CAN H - Bus #1 | confirmed | ||
10 | Powertrain CAN bus, low | Powertrain CAN bus, low | CAN L - Bus #1 | confirmed | ||
11 | Hybrid CAN bus, high | Hybrid CAN bus, high | CAN H - Bus #2 | |||
12 | Hybrid CAN bus, low | Hybrid CAN bus, low | CAN L - Bus #2 | |||
13 | HVIL IN | HVIL IN | Pilot Line In | |||
14 | LIN Comms | |||||
15 | HVIL OUT | HVIL OUT | Pilot Line Out | |||
16 | Lock drive +. Drive to 12v to close lock. | The lock can be coded off with ODIS | Plug Lock (+) - Socket A | |||
17 | Lock Drive – Drive to 12v to open lock | Plug Lock (-) - Socket A | ||||
18 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Position - Socket A | ||||
19 | Lock feedback. 1K fully locked ,11K Plug Locked, 1K overtravel | Plug Lock Ground - Socket A | ||||
20 | ||||||
21 | Immediate charge buttons | Function LED #1 | ||||
22 | Charge Port RGB LED +12v o/p | |||||
23 | Control Pilot (CP) | CP - Socket A | ||||
24 | Plug Present (PP) (4.7K to ground in socket) | PP/CS - Socket A | ||||
25 | Immediate charge buttons | Charge Button - Socket A | ||||
26 | Search Light (Shared - Possible LED4 in config) | |||||
27 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (-) - Socket A | ||||
28 | Temperature sender for charging socket. 1067R at approx 15C | AC Charge Port Temperature Sensor (+) - Socket A | ||||
29 | Charging Cover Position Switch - Socket A | |||||
30 | AC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
31 | Charge port door lock actuator | The flap can be coded off with ODIS | Charging Cover Lock (+) - Socket B | |||
32 | Charge port door lock actuator | Charging Cover Lock (-) - Socket B | ||||
33 | Charge port door lock actuator | Charging Cover Position Switch - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
34 | Charge port door lock actuator | |||||
35 | Switch/LED Common - Socket B | confirmed | ||||
36 | LED - Red - Socket B | confirmed | ||||
37 | LED - Green - Socket B | confirmed | ||||
38 | LED - Blue - Socket B | confirmed | ||||
39 | Illumination LED - Socket B | confirmed / Other side tied to ground pin* (Debating if this should be tied to the 3/45 pins) | ||||
40 | CP - Socket B | confirmed | ||||
41 | PP/CS - Socket B | confirmed | ||||
42 | ||||||
43 | ||||||
44 | ||||||
45 | Switch/LED Common - Socket B | confirmed / Both pin 3 and 45 can be tied together | ||||
46 | Plug Lock (+) - Socket B | confirmed | ||||
47 | Plug Lock (-) - Socket B | confirmed | ||||
48 | Plug Lock Position - Socket B | confirmed / Resistive 1k/11k unlocked/locked) *Other side tied to sensor ground pins 3/45* | ||||
49 | DC Charge Port Temperature Sensor (+) - Socket B | confirmed | ||||
50 | Charging Cover Lock (-) - Socket A | |||||
51 | Immediate charge buttons | Charge Button - Socket B | confirmed / Other side tied to sensor ground pins 3/45 | |||
52 | DC Charge Port Temperature Sensor (-) - Socket B | confirmed | ||||
53 | Chademo CAN-H | |||||
54 | Chademo CAN-L | |||||
55 | Chademo | |||||
56 | Chademo | |||||
57 | ||||||
58 | ||||||
59 | ||||||
60 | Terminal 31 (Ground) | Terminal 31 | confirmed |
AC Connection
Golf GTE and all 5QE915682 series 3.6 kW chargers - Part number TE Connectivity 2103177-2
HV Connection
Coding
MLBevo chargers seem to all use the EV_OBC3Phase1KLOMLBev16B config/odx
VCDS
You can open in the VCDS LCode.exe program (no purchase needed) and it's a interactive way to determine the coding value required. Coding label file available here. Shouldn't be necessary for newer versions of VCDS.
Bitfield 0 | Bitfield 1 | Bitfield 2 | Bitfield 3 |
CP standard - SAE/
Country encoding (NAR/
Mobile Online Services (MOD)
Charging cover lock detection (charging socket B)
Bitfield 4 | Bitfield 5 | Bitfield 6 | Bitfield 7 |
Plug and Charge (PnC)
Variant coding 11 kW (reserve)
DC China socket installed
Installation location DC charging socket |
ODIS
PIWIS
CAN-Messages
RX Messages:
TX Messages:
Required:
- BMS_01 - 0x191
- BMS_02 - 0x1A1
- BMS_03 - 0x39D
- BMS_04 - 0x5A2
- BMS_06 - 0x59E
- BMS_07 - 0x5CA
- BMS_09 - 0x96A955EB
- BMS_10 - 0x509
- BMS_11 - 0x96A954A6
- BMS_27 - 0x9A555552
Signals I'm sending In addition:
Signals I haven't added:
- Dimmung_01 - 0x5F0
- Einheiten_01 - 0x643
Reference Implementations:
- ↑ From Forum Reference: https://openinverter.org/forum/viewtopic.php?p=47620#p47620 VW Parts Store:https://parts.vw.com/p/Volkswagen__/Housing/64431217/5Q0906379.html (Backup: Web Archive)
