Lexus GS450h Drivetrain
- Two high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps. [1]
Weight: 40 lbs
Buck/Boost Converter
Transmission
MG1 speed is -2.29:1[4]
Oil Pump
Overview and location
The Internal pump and pressure regulator provides a steady 7 Bar oil pressure.[6]
Wiring and control
Pinouts, schematics and notes
Gasket (1) 35142-30010 $14
Wiring Harness Connectors
Inverter Connectors
OEM
90980–12630 |
8100-3456 (Gold) |
8240-0288 (Gold) | ||||||
2.3 II
0.040" |
Alternatives
Molex MX123 series
Image | Part No. | Item | Quantity |
036638-0002 | CMC header connector 48pin | 1 | |
064320-1311 | CMC receptacle 48pin | 1 | |
064320-1301 | CMC wire cap | 1 | |
064323-1039 | CP terminal | 4 | |
064322-1039 | CP terminal | 32 | |
064325-1010 | CMC plug | 8 | |
064325-1023 | CMC plug | 4 |
Assembly Instructions
Instructions on how to assemble the MX123 connector can be found here [7].
Transmission Connectors
Connector | Toyota Part No. | Part No. | Terminals | QTY | Terminal Size Opt 1 | Terminal Size Opt 2 | Terminal Size Opt 3 | Location | |
ECT Solenoid (E83) | Toyota 90980-12326 | Sumitomo 6189-1092 | TS 025 Series
( 0.025" 0.64mm )
Female - 13 | .13 mm2 / 26 AWG | .22-.35 mm2 / 24-22 AWG | .5 mm2 / 20 AWG | Located on the left hand side of the transmission above the oil pan. | |
Sumitomo 8240-0336 (Tin) | Sumitomo 8100-3455 (Tin) | 8240-0287 (Tin) | |||||||
8100-3456 (Gold) |
8240-0288 (Gold) | |||||||
Shift Lever Position Sensor (E80) | Toyota 90980-12362 | Sumitomo 90980-12362 | TS 025 Series
( 0.025" 0.64mm )
Female - 7 | 20-22 AWG /
.3-.5 mm2 |
16-18 AWG /
.85-1.25 mm2 |
14 AWG / 2.0 mm2 | Located on the right side of the transmission next to the shift lever inhibitor switch. | |
Yazaki - 7116-4025 (Tin) | Yazaki - 7116-4026 (Tin) | Yazaki - 7116-4027 (Tin) | |||||||
Yazaki - 7116-4028-08 (Gold) | Yazaki
7116-4029-08 (Gold) |
TS 090II Sealed Series
( 0.090" / 2.3mm ) (6mm LIF variant) |
Female - 2 | .3-.5 mm2 (22-20 AWG) | .5-1.25 mm2 (20-16 AWG) | 2.0 mm2 (14 AWG) | |||||
8100-0460 - (Tin) | 8100-0461 (Tin) | 8100-0462 (Tin) | |||||||
8100-1344 - (Gold) | 8100-0594 (Gold) | 8100-0817 (Gold) | |||||||
MG1 & MG2 Resolver(s) (E81 & E82) | Toyota 90980-12520 | Sumitomo 6189-1240 | TS 025 Series
(0.025" 0.64 mm) |
Female - 8 | .13 mm2 / 26 AWG | .22-.35 mm2 / 24-22 AWG | .5 mm2 / 20 AWG | Two connectors located on the left side of the transmission by the bell housing. | |
8100-3456 (Gold) |
Vehicle Speed Sensor Connector | Toyota # 90980-11153 [?] | S-1530 [?] |
2.3-2.7 mm (.090-.106 in) | Brown | 7158-3008-80 |
3D Printable Parts
Control Schemes
ZombieVerter VCU
Lexus GS450h VCU (deprecated)
These parts are available from many electronics distributors. VCU FirmwareFirmware to run on the VCU is available on Github : https://github.com/damienmaguire/Lexus-GS450H-Inverter-Controller This guide relates to V3.01 available here on Github : https://github.com/damienmaguire/Lexus-GS450H-Inverter-Controller/blob/master/Software/gs450h_v3_user.ino A video tutorial to accompany this guide and firmware is available here :https://vimeo.com/501777258 In order to aid those not familiar with programming, a new firmware with a basic serial interface is now available. This will be the default loaded onto all VCU boards sold on the EVBMW webshop as of 18/01/21. This firmware is intended as a stop gap measure before a new Openinverter based version with a web based interface becomes available. (expect mid 2021). Instructions for useConnect a USB cable between the VCU and a PC. Using a serial terminal program of your choice, connect at 115200,8,N,1. Once connected, type ? and press enter. The following menu should then display : =========== EVBMW GS450H VCU Version 3.01 ============== ************ List of Available Commands ************ ? - Print this menu d - Print received data from inverter D - Print configuration data f - Calibrate minimum throttle. g - Calibrate maximum throttle. i - Set max drive torque (0-3500) e.g. typing i200 followed by enter sets max drive torque to 200 q - Set max reverse torque (0-3500) e.g. typing q200 followed by enter sets max reverse torque to 200 v - Set gearbox oil pump speed (0-100%) e.g. typing v50 followed by enter sets oil pump to 50% speed a - Select LOW gear. s - Select HIGH gear. z - Save configuration data to EEPROM memory ************************************************************** The menu system allows for the display of data from both the VCU, GS450H Inverter and gearbox as well as setting of parameters such as throttle calibration and maximum torque. To select a menu option type its associated character followed by enter. ? Will display the menu. d Displays data from the inverter in this format : 0 1 2 3 4 5 6 7 8 9 ------------------------------------------------------------------------------ 00 | 0 0 10 | 0 0 0 0 0 0 0 0 20 | 0 0 0 0 0 0 0 0 0 0 30 | 0 0 0 0 0 0 40 | 0 0 0 0 0 0 0 0 50 | 0 0 0 0 0 60 | 70 | 80 | 0 0 0 0 0 0 90 | 0 0 0 0 0 0 0 0 MTH Valid: Yes Checksum: 0 DC Bus: ----v MG1 - Speed: 0rpm Position: 0 MG2 - Speed: 0rpm Position: 0 Water Temp: 0.00c Inductor Temp: 0.00c Another Temp: 0c Another Temp: 0c D (capital or large D) displays VCU configuration data as well as information on the Gearbox status in this format : *************************************************************************************************** Throttle Channel 1: 109 Throttle Channel 2: 53 Commanded Torque: 0 Selected Direction: DRIVE Selected Gear: HIGH Configured Max Drive Torque: 600 Configured Max Reverse Torque: 300 Configured gearbox oil pump speed: 40 Current valve positions: PB1:ON PB2:ON PB3:ON MG1 Stator temp: 109.69 MG2 Stator temp: 109.69 *************************************************************************************************** Throttle calibration procedure : Set your throttle, be it a pedal or potentiometer or other, to the position of desired zero throttle. Type f and press enter. A response like this will display: Configured min throttle value: 109 Now press or advance the throttle to the desired position of maximum throttle. Type g and press enter. A response like this will display: Configured max throttle value: 633 The throttle calibration is now complete. Next we want to set the maximum allowed drive and reverse torque values. The GS450H inverter will accept a value of between 0 and 3500 for torque. for initial bench and vehicle testing it is advisable to limit these to low values. In this example we will set drive torque to 500 and reverse torque to 300. First, drive torque: Type i500 followed by enter. A response like this will display: Configured drive torque: 500 Now reverse torque: Type q250 followed by enter. A response like this will display: Configured reverse torque: 250 Torque calibration is now complete. At this point it is advised to store the now configured values to EEPROM (non volatile memory) by typing z followed by enter. A response like this will display: Parameters stored to EEPROM An option is provided to set the speed in % (0 to 100%) for the electric gearbox oil pump. In this example we set the speed to 50% : Type v50 followed by enter. A response like this will display: Configured gearbox oil pump speed: 50 I have found in testing on the E65 that 50% is a good value for keeping oil pressure up , providing cooling etc. without running the pump too hard. Your millage may vary. An option is provided to shift between LOW and HIGH gear in the GS450H gearbox. Shifts are inhibited at MG1 or MG2 speeds above 100rpm for safety at this time. To select LOW gear type a and press enter. A response like this will display: LOW Gear Selected To select HIGH gear type s and press enter. A response like this will display: HIGH Gear Selected It is advised to leave HIGH gear selected always at this time until further testing and development has been completed. Finally, store all parameters to EEPROM once more by typing z and press enter. A response like this will display: Parameters stored to EEPROM Selecting Direction. The firmware supports the use of the IN1 and IN2 pins of the V2 VCU as direction control inputs. Operation is as follows : If both inputs are unconnected, NEUTRAL is selected. In neutral , no torque commands are transmitted to the inverter regardless of throttle application. If IN1is connected to +12v , DRIVE is selected. In drive both MG1 and MG2 provide torque in a forward direction to the gearbox output shaft. If IN2 is connected to +12v , REVERSE is selected. In reverse only MG2 provides torque in a reverse direction to the gearbox output shaft. Currently this "simple" firmware does not support contactor control. This may be provided in a later version. Wi-Fi DisplayA Wi-Fi web browser based display is provided in order to easily visualise data from the inverter and gearbox. Once powered, the Wi-Fi module will create an open access point with an SSID like ESP-XXXX where XXXX will be a series of letters and numbers. Connect to this access point with any Wi-Fi enabled device (e.g. laptop, tablet, phone etc.). Some modern devices will try to access the internet, not find it, and pop up a warning. Dismiss this and open a web browser. Type 192.168.4.1 into the address bar and press enter. Again, some modern devices and browsers will complain that it is not a secure connection etc. Just dismiss the warning and proceed. After a few seconds the web gauge display will appear. Note that the voltage display is derived from the voltage reported by the inverter and both current (amps) and power (kw) gauges are inoperative as of this release. You may wish to change the SSID and add a passphrase to the access point. To do this goto : 192.168.4.1/admin A simple set of dialog boxes will allow the SSID, passphrase and background colour of the gauge display to be set. In newer versions (October 2020 onwards) of the VCU Board, the default SSID and Password will be `gs450h_vcu` and `inverter123` respectively. Development HistoryV1 - This board was sold tested but also as a bare logic board requiring purchase of your own components and SMD placement and soldering skills. https://www.evbmw.com/index.php/evbmw-webshop/toyota-bare-boards/gs450h-bare-pcb (No longer available). V2 - A new board source was found to be both high quality and low cost. The boards were redesigned around the inventory of parts available from this supplier. In particular the high cost of populated and soldered boards (10x the price) from the source used to make the v1 boards is so significantly lower on the v2 that there are likely no savings by building and soldering the board yourself. Software is still in development. VendorsEVBMW: [8] NOTE: There are currently no vendors who offer support on any aspects of the GS450h VCU. SupportCommunity support is available on the Lexus GS450H VCU Support Thread |
- ↑ 2.0 2.1 https://www.osti.gov/servlets/purl/928684
- ↑ 3.0 3.1 https://www.osti.gov/servlets/purl/947393
- ↑ 4.0 4.1 [1]
- ↑ 8.0 8.1 https://www.evbmw.com/index.php/evbmw-webshop/vcu-boards/gs450h-vcu (Backup: Web Archive)
