VAG CCS2 Charge Port
Revision as of 17:52, 20 December 2024 by Tom91 (talk | contribs) (Categories)
Charge port itself is part number 12E915561 [information seems to be wrong. This looks like the VW Up charge port only. Wont make you happy with any 3 phase charger]. Used in many VAG models. Usually consists of the charge port with locking actuator, two small black connectors with signal cables. Then two larger HV looms, one running to a VW charger and the other CCS cables to the junction box.
Signal pin outs
4 pin connector to interlock. 1J0973704 is the part number for the connector to plug into this.
1. Lock drive - 12v to open
2. Lock feedback
3. Lock feedback
4. Lock drive + 12v to close
10 pin connector. 1J0073715 is the part number for the connector to plug into this.
1. LED ground
2. LED red 12v
3. LED green 12v
4. LED yellow 12v
5. PP
6. CP
7. Temp sender?
8. Temp sender?
9. Temp sender?
10. Temp sender?
