MG ZS Charger
Revision as of 23:55, 6 January 2025 by Manny (talk | contribs) (Added <br> to tabel)
MG ZS Charger Part number(s)
Part Number Description Phases AC/DC Input 1 AC/DC Input 2 AC/DC Output 1 AC/DC Output 2 DC/DC Input DC/DC Output
ZS10BC6600A (10822241) MG ZS AC Charger single phase 85-265V 32A Max N/A 230-480V 20A Max 6.6KW Max N/A N/A N/A
EP2CCU1130A (11276088, 11428079) MG ZS AC Charger three phase 85-265V 32A Max 85-265V 16A Max 250-500V 24A Max 250-500V 32A Max 250-500V 9-16V 220A Max@13.V
EP3CCU1130B (11489298) MG 4 Charger ??? phase 85-265V 32A Max 300-456V 16A Max 220-490V 24A Max 220-490V 31.5A Max 220-490V 9-16V- 220A Max@13.5V
EH3CCU6630B (11572315) MG4 Trophy ??? Phase 85-265V 32A Max N/A 220-490V 22A Max N/A 220-490Vdc 9-16V 220A Max@13.5V
EP2CCU6625A (11237810) MG5 ??? phase 85-265V 32A Max N/A 230-450V 22A Max N/A 230-450Vdc 13A Max 9-16V 178A Max@14V
Example offer
EV Breakers - MG ZS ONBOARD BATTERY CHARGER 2019-2024 (archive.org) - 08-2024, GPB 300
https://www.bildelsbasen.se/sv-se/pb/S%C3%B6k/Bildelar/s1/MG/MG-ZS-EV/2020_2025/EL-&-Givare-&-Databox-&-Sensor/Batteriladdare-H%C3%B6gsp%C3%A4nning/_/ID-60187841/11428079 - 08-2024; 5000 SEK
Video of Damien hacking it
MG ZS EV Charger Hacked N.B It's not confirmed yet whether all chargers accept the same CAN messages for control, more investigation is needed.
MG ZS EV Charger Hacked Part 2 (Damian demonstrating ZS10BC6600A from the above list, further investigation required to see if all chargers respond to the same CAN messages)
Damien's GitHub page
https://github.com/damienmaguire/MG-EV-Charger
Connectors
Charger part number Low voltage High voltage (DC) High voltage (AC)
ZS10BC6600A (10822241) 33472-1201 (housing)
33012-2021 (pin)
2103177 (housing)
1355036 (pin)
13879047 (housing)
13955308 (power pin)
13711549 (signal pin)
EP2CCU1130A (11276088, 11428079) 64319-1211 (housing)
64322 (0.635mm pin)
64323 (1.50mm pin)
HVC2P28FSX02 (2.5mm² Shield)
HVC2P28FSX04 (4.0mm² Shield)
HVC2P28FSX05 (5.0mm2 Shield)
“X” indicates code 1/2/3/4/5/6
HVC5P63FSx06
“X” code: CODE A:1/CODE B:2/CODE Z:0
