Connector Part Numbers
This page contains part numbers for connectors on various openinverter boards
Nissan leaf gen2 inverter
https://openinverter.org/forum/viewtopic.php?t=2939
| part type | part name | part number | remarks |
| connector housing | toyota | G9260-47010 | 36pin |
| connector housing | toyota | G9266-47010 | 13pin, mounts into 36pin housing |
| large terminals | Sumitomo | 8100-0460 | 2.3:
0,3-0,5mm2 |
| sumitomo | 8100-0461 | 0,8-1,25mm2 | |
| Sumitomo | 8100-0462 | 2,0mm2 | |
| Large wire seal | sumitomo | 7165-0342 | D4,9mm d1,4-2,0mm |
| sumitomo | 7165-0343 | D4,9mm d2,0-2,5mm | |
| sumitomo | 7165-0344 | D4,9mm d2,5-2,9mm | |
| large blind plug | sumitomo | 7161-9787 | D4,7mm |
| small terminals | sumitomo | 8100-3455 | 0.64:
0,22-0,35mm2 |
| small wire seal | sumitomo | 7165-1198 | |
| small blind plug | sumitomo | 7165-0797 |
Prius Gen2 Inverter Controller
| Part Type | Part Name | Part Number | Remarks |
| Header | 10-pole 90° Header | 61201021721 | |
| Header | Cinch 12+20 header | 5810132011 | |
| Enclosure | Cinch enclosure | 5810130065 | |
| Connector | Molex 20-pin | 0334722002 | |
| Connector | Molex 12-pin | 0334721201 | |
| Pin | Molex Pin | 0330122002 | |
| Connector | TE 32-pin (inside inverter) | 1318747-1 | |
| Pin | TE pins (inside inverter) | 1123343-1 |
Chevy Volt Gen2 Charger P/N 24281923
| LV Connector | Molex MX150 | 33472-1201 | https://openinverter.org/forum/viewtopic.php?t=1690# |
| HV DC connector | TE HVA280 | 2103628 | https://www.te.com/en/product-2103628-1.html |
| HV AC Connector | Aptive HES 6 Way Connector Type 103 | 13879048 | https://eu.mouser.com/ProductDetail/Aptiv-formerly-Delphi/13879048?qs=ZkWKQR8GT5%2FbuA9eSR%2FFiA%3D%3D |
| HV AC Connector pins | Aptive HES Type 103 Pins | 13783301-L | https://eu.mouser.com/ProductDetail/Aptiv-formerly-Delphi/13783301-L?qs=42rJWdla%2FgotUv9ir%252B%2FFiA%3D%3D |
Chevrolet Volt Gen2 DC-DC converter P/N 24281923
| JST LV CONNECTOR | ATSSPB-C0802Y-1AK | 33472-1201 | https://eu.mouser.com/ProductDetail/JST-Automotive/ATSSPB-C0802Y-1AK?qs=xwQlLnDx56Cob1elKfHzRw%3D%3D |
| HV CONNECTOR | DELPHI / APTIV | 33107347 | https://eu.mouser.com/ProductDetail/Aptiv-formerly-Delphi/33107347?qs=apCURoLtCZHBY9y%252BDPZL3w%3D%3D |
FOCCCI
| Header | Deutsch 12+12 header | ATM13-12PA-12PB-BM03 | https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/ATM13-12PA-12PB-BM03/9953955 |
| Enclosure | Enclosure | EEC-325X4B | https://www.digikey.de/de/products/detail/te-connectivity-deutsch-ict-connectors/EEC-325X4B/6566624 |
| Connector | Amphenol 12-pin grey | ATM06-12SA | https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/ATM06-12SA/5227558 |
| Connector | Amphenol 12-pin black | ATM06-12SB | https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/ATM06-12SB/5227559 |
| Pin | Pin matching Deutsch header | AT62-201-20141 | https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/AT62-201-20141/5227536 |
| Wedge | CONN PLUG WEDGE 12POS | AWM-12S | https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/AWM-12S/5227596 |
ELCON 1000W DCDC Converter
Current Sensor
| Sensor | DHAB S-137 (1000A) | 398-DHABS/137-ND | https://www.digikey.com/en/products/detail/lem-usa-inc/DHAB-S-137/22118080(much less expensive than getting from an EV store) |
| Sensor | DHAB S-124 (500A) | 398-DHABS/124-ND | https://www.digikey.com/en/products/detail/lem-usa-inc/DHAB-S-124/22117976 |
| Connector | AMP 4-pin | A127756-ND | https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-1456426-5/5437233 |
| Pin | 15-17 Awg (4) | A142535TR-ND | https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1418850-1/2311440 |
| Seal | 1 POS (4) | 964972-1 | https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/964972-1/2054543 |
OEM Battery Connectors
| OEM | Manufacturer | Specs | Part Type | Part Name | Part Number | Remarks |
| Mercedes | CATL | 18S1P Prismatic | BMS | isoSPI connector | 17-2177587-1-ND | https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/2177587-1/10478170 |
| Pin | 22-24 Awg (4) | A132542TR-ND | https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/2-1703930-1/8638371 |
Battery Connectors
| Used in | Manufacturer | Specs | Part Type | Part Name | Part Number | Remarks |
| Nissan Leaf | Aptiv / FCI | RCS800 wire side | Connector housing | Key 1 (Black) | F673110(-B) OR 13974469 (Same part) | https://fi.farnell.com/aptiv-formerly-delphi/13974469/plug-housing-2pos-pbt/dp/3019247 |
| Renault Zoe? | Aptiv / FCI | RCS800 wire side | Connector housing | Key 2 (Brown) | F773110-B OR 33511761 (Same part) | https://fi.farnell.com/aptiv-formerly-delphi/33511761/plug-housing-2pos-pbt/dp/3019248 |
| RCS800 wire side connector housing | Aptiv / FCI | RCS800 wire side | Female contact | 35-50mm2 | F385400 OR 13893887 (Same part) | https://www.mouser.fi/ProductDetail/Aptiv-formerly-Delphi/F385400?qs=biNArH83b7NOmmzNuHgkqQ%3D%3D |
| RCS800 wire side connector housing | Aptiv / FCI | RCS800 wire side | Female Side Wire Seal BLACK | for 35mm2 wire | F427600(-B) OR 13893888 (Same part) | https://www.mouser.fi/ProductDetail/Aptiv-formerly-Delphi/F427600-B?qs=biNArH83b7Okx2eym9OVsg%3D%3D |
| RCS800 wire side connector housing | Aptiv / FCI | RCS800 wire side | Female Side Wire Seal GREY | for 50mm2 wire | F327600(-B) OR 13923559 (Same part) | https://www.mouser.fi/ProductDetail/Aptiv-formerly-Delphi/F327600?qs=biNArH83b7MJBzOmsKEdjQ%3D%3D |
| RCS800 wire side connector housing | Aptiv / FCI | RCS800 wire side | Female Side Wire Seal retainer | for female side connector | F527600(-B) OR 13893889 (Same part) | https://www.mouser.fi/ProductDetail/Aptiv-formerly-Delphi/F527600?qs=biNArH83b7MFx%252B0Sf36knA%3D%3D |
| Nissan Leaf | Aptiv / FCI | RCS800 battery side | Connector housing | Key 1 (embossed on housing) | F473110(-B) OR 33511764 (Same part) | https://www.mouser.fi/datasheet/2/105/delphi_01172018_pcc0732944_d_1-pdf-1284387.pdf |
