CAN table CAN STD
Revision as of 10:07, 14 June 2023 by Marcexec (talk | contribs)
The Status cell will have several status like:
  • Suggested,
  • Approved, looks good go ahead and put in firmware
  • STD, is established and standard in firmware
Sign with your forum name, please do not delete any rows, just add a new.
Openiverter CAN data out.
Function CAN-Id Byte0 Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 Byte7 Description Status Sign
Inv. temp 0x3FF 0-255 -128 to 127 Suggested joromy
Motor temp 0x3FF 0-255 -128 to 127 Suggested joromy
AUX 12volt 0x3FF LSB MSB 0 to 255 Suggested joromy
N/P 0x3FF 0 Suggested joromy
FWD 0x3FF 1 Suggested joromy
REV 0x3FF 15 Suggested joromy
Motor ON 0x3FF 1 ON-1, OFF-0 Suggested joromy
RPM 0x3FF LSB MSB 0 to 65k Suggested joromy
Simp BMS CAN data out.
SOC 0x355 0-100 STD joromy
BMS Boot 0x355 0 Status Suggested joromy
BMS Ready 0x355 1 Status Suggested joromy
BMS Drive 0x355 2 Status Suggested joromy
BMS Charge 0x355 3 Status Suggested joromy
BMS Precharge 0x355 4 Status Suggested joromy
BMS Error 0x355 5 Status Suggested joromy
BMS Heat/cool 0x355 6 Staus Suggested joromy
Pack Volt 0x356 LSB MSB STD joromy
Tot. Amps 0x356 LSB MSB STD joromy
Avg. celltemp 0x356 LSB MSB STD joromy
Lo cellvolt 0x373 LSB MSB Suggested joromy
Hi cellvolt 0x373 LSB MSB Suggested joromy
Lo celltemp 0x373 LSB MSB Suggested joromy
HI celltemp 0x373 LSB MSB Suggested joromy
Tesla charger CAN data out. (only DUE based board)
Unconnected 0x3D8 0 Suggested joromy
Buttonpress 0x3D8 1 Suggested joromy
Connected 0x3D8 2 Suggested joromy
EVSE disable 0x3D8 0 Normal mode Suggested joromy
EVSE enable 0x3D8 1 AC enable, no charge Suggested joromy
Tesla drive units CAN data out.
Function CAN-id Byte0 Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 Byte7 Description Status Sign
DC Amp 0x135 LSB MSB Suggested joromy
Pack Volt 0x135 LSB MSB Suggested joromy
AUX 12volt 0x135 Not implemented 0-255 Declined johu
Overcurrent 0x135 0/1 Active = 1 Suggested joromy
AC Amp 0x135 LSB MSB Suggested joromy
Off 0x136 0 Suggested joromy
Run 0x136 1 Suggested joromy
Man Run 0x136 2 Suggested joromy
Chg Boost 0x136 3 Suggested joromy
CHG Buck 0x136 4 Suggested joromy
Sine 0x136 5 Suggested joromy
2 ph Sine 0x136 6 Suggested joromy
REW 0x136 -1 Suggested joromy
N/P 0x136 0 Suggested joromy
FWD 0x136 1 Suggested joromy
RPM 0x136 LSB MSB 0 to 65k Suggested joromy
HS temp 0x136 0-255 -128 to 127 Suggested joromy
Motor Temp 0x136 0-255 -128 to 127 Suggested joromy
