Mitsubishi Outlander Front Transaxle
Gearbox
Weight TBC
Motor - Differential ratio 9.663
Generator - Engine ratio 2.736
Engine - Differential ratio 3.425
Item N·m
Drain plug 35 ± 4
Filler plug (the underside) 32 ± 2
Filler plug (the upper side) 35 ± 4
Break off bolt <Vehicles for England> 7.5 ± 1.5
Electrical parking actuator mounting bolts 28 ± 4
Valve body assembly mounting bolts 9.0 ± 2.0
Plug(Valve body) 7.0 ± 1.0
Connector mounting bolts 7.0 ± 1.0
The 'generator'
It looks like this is the motor that is sold by SLEVB as https://www.secondlife-evbatteries.com/70kw-ev-motor-with-14000rpm.html Interestingly they claim it as 70kw, where as the motor as 60kw, both weigh the same. This is the motor that bobby_come_lately has with the looks of it. Weight: 29.5kg
[attachment=1]6-pin-outlander-phev-motor-connector.png[/attachment]
Pin 11 GTH1 - temperature in the U-phase coil (+ve) Pin 12: GTH2 - temperature in the W-phase coil (+ve) Pin 13: TH0 - oil temperature thermistor (+ve) Pin 14: GTG1 - temperature in the U-phase coil (-ve) Pin 15: GTG2 - temperature in the W-phase coil (-ve) Pin 16: TG0 - oil temperature thermistor (-ve)
[attachment=0]8-pin-outlander-phev-motor-connector.png[/attachment]
Pin 1: R1 - the first connection for the exciter coil Pin 2: S1 - the first connector for output coil 1 Pin 3: S2 - the first connector for output coil 2 (S2-1) Pin 4: R2 - the second connection for the exciter coil Pin 5: S3 - the second connection for output coil 1 (S1-2) Pin 6: S4 - the second connection for output coil 2 (S2-2) Pin 7: GGND - earth connection to the ECU
The motor
It looks like this is the motor that is sold by SLEVB as https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-14000rpm-electric-project-emrax-replacement.html Weight: 29.5kg
