Mitsubishi Outlander Rear Drive Unit
Revision as of 22:47, 7 December 2020 by ScottS (talk | contribs) (Added link back to other Mitsubishi parts page)
Property Value Source
Device Combined Motor, Gearbox and Rear Differential
OEM Mitsubishi
Type AC Motor 10 Pole 3 Phase synchronous perm magnet brushless https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html
https://openinverter.org/forum/viewtopic.php?f=19&t=325&start=30
Manufacturer Meidensha https://www.meidensha.com/products/case/prod_05/prod_05_01/prod_05_01_01/prod_05_01_01_01/1210605_4260.html
Suppliers Ebay, Second Life EV Batteries https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html
Max RPM 9600RPM
Mechanical Mounting 6x M10 Bolt front face flange (all in same plane)
3x M? Bolt Rear Flange (all in same plane) used for bush mount on Outlander
Author experience
Shaft Type 20.02mm 18 splines, ~60mm long
Clutch plate from a Suzuki Jimny SJ410 appears to fit, part number ADK83106
Resolver SIN COS - P/N C69600/TS2239N484E102
Believed to be similar to Nissan Leaf resolver
https://photos.google.com/share/AF1QipMNz2BVPSATZFJxgwIvy0RAeNAwn0TLJJL7NBwxbpH32LbWNkGhybiNrdkTsTOLxg?key=TmNWY04zNFQ4cXZzNWUzUEJfcTZUeGtHVkxyZEtB
Cooling Water/glycol cooling (Blue on Outlander) Author experience
Weight 42kg https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html
Power To Weight Ratio 70kW Motor: 1.66 kW/kg
Diff Ratio 7.065:1 http://www.mitsubishi-motors.com.hk/uploads/file_1465376705.pdf
Example Ebay Listing:
Description
The Mitsubishi Outlander PHEV (Plug-in Hybrid) uses 3x AC motor/generators - 2 in the front gearbox (One is designated as a generator) and 1 in the rear. The rear motor appears to be the more powerful of the 3, and it is coupled to a rear differential unit which is mounted underneath the vehicle. The Rear differential has female driveshaft splines and a ratio of 7.065:1. The motor is driven by a dedicated rear inverter unit, and the combined system appears to have different power ratings in different model years. The whole unit could lend itself well to rear engined/rear wheel drive EV conversion applications - e.g. Toyota MR2, VW Beetle, rear engined Porsches, Lotus. The Motor can also be easily decoupled from the Gearbox/Differential unit and with an adaptor plate and coupling could be used on either Front wheel drive applications, or Front engined, rear wheel drive. There are already some examples of the drive being used with the OpenInverter, and also with the OEM motor inverter.
Power Rating
Model Years Motor Power Motor Torque Part Number
TBC - TBC 50 kW TBC Y61
TBC - 2018 60 kW 195Nm Peak Y61
2018 - 70 kW 195Nm Peak Y61
Mitsubishi/FUSO part numbers include 9411A078, 9499D132, 9499D146, and MEIDEN part numbers include F1E1A2B5Z
Connectors:
HV: 3x 3 phase lug connections with HV gland plate
Datasheet: https://www.hirose.com/product/document?clcode=&productname=&series=GT18W&documenttype=Catalog&lang=en&documentid=D49386_en
R12 - 35,5R Black, White
S13 - 86,4R Green, Red
S24 - 78,5R Yelow, Blue
Vehicle Wiring Diagrams:
http://mmc-manuals.ru/manuals/outlander_iii/online/Service_Manual_2013/2019_phev/index_M1.htm
Links
Other Mistubishi OEM Parts on Open Inverter
