VW Touran Conversion
I will start loosely collecting infos on the VW Touran from 2004.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I will have to look into reading the pedal directly. Here is its pin map:
Throttle pedal pin map
Pin # Color code Function
1 green/white 5V
2 yellow/green 5V
3 brown/blue GND
4 white/blue Throttle 1 0.75V-4.1V
5 green/blue GND
6 blue/black Throttle 2 0.38-2.05V
ECU connector
11 - Throttle GND (Pin 5)
12 Throttle 2 out (Pin 6)
13 Throttle 5V (Pin 1)
33 Throttle GND (Pin 3)
34 Throttle 1 out (Pin 4)
35 Throttle 5V (Pin 2)
31 Vacuum sensor 5V
37 Vacuum sensor GND
83 Vaccum sensor signal
86 Ignition On?
87 While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU
67 CAN (high or low, t.b.d.)
68 CAN
Power steering
CAN bus
Some Touran CAN messages
COB Id Len Function Notes
0x380 Byte 2: 0-0xFE throttle position Produced by ECU, so n/a when removed
0x1A0 1 Byte 1, Bit 3: Brake pedal switch Produced by whoever
0x280 Bytes 2 and 3: RPM*4 Produced by you, Controls the rpm gauge
0x480 8 Byte 6, Bit 2: Cruise light, Byte 1, Bit 3: EPC, Bit 4: engine Controls various indicator lights
0x288 Byte 1: Temp Gauge 0.75x temp - 48 Produced by you, Controls temp gauge
0x38A Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+
0x572 Byte 0, Bit 3: Key switch in start position
Faults
After powering up the engine I got two error messages: STOP low coolant and something about an oil sensor. The first can be solved by filling the reservoir with water. The second is probably down to the missing oil level sensor. I will investigate. Update on oil level warning: I fitted a 470 Ohm resistor from pin 1 to pin 3 and the warning is gone
