VW Hybrid Battery Packs
Revision as of 10:32, 31 March 2021 by Bigpie (talk | contribs) (→‎Golf GTE: Adding external connector pinout)
Specification Overview
Passat GTE
Golf GTE
Pin Colour Notes
3 Blue Airbag Control Module
4 Purple & Yellow
6 Red & Grey
7 Green Coolant Pump
8 Black & Green I
9 Brown Earth
10 Red & Grey 12v 30amp Fuse
11 Black & Green
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
Golf GTE
Main terminal
Main terminal
BMS
ID Data
Battery Modules
Passat GTE
Module Weight
BMS Board
Golf GTE
Module Label
Module Label
Lower Mounting bracket
Higher mounting bracket
BMS slave Board
BMS slave Board
BMS Master Top
BMS Master Top
BMS Master Bottom
BMS Master Bottom
Cooling
Original Pipework Connector
Contactors/Pre-Charge
Passat GTE
The Control box contains
  • PEC 300A 450VDC fuse
  • 1 x Contactor Control Board
Contactor Box
HV Contactor
Pre Charge Relay
pre charge resistor
Fuse
Shunt
Control Board
TE 1-963539-1
The pinout is as follows:
1 Green
2 Green
3
4 Black/Grey
5
6 Brown
7
8 GND Brown/Red
9 GND Brown/Red
10 +12V Red
11
12
13
14 CANH Orange/Blue 120 OHM
15 CANL Orange/Brown 120 OHM
16 +12V Yellow
17
18 GND Brown/Red
Can output ...
CAN ID Function Notes
18FED007
0000015B
18FED008
18FED00A
18FED003
18FED004
1A55545F
16A95419
18FED006
18FED002
18FED005
BMS Control Module
BMS Control Module
BMS MASTER PCB
6 Twisted Pairs (12)
000000BA Module Wake up
1BFFDA1A
1BFFDA19
1A55540A
1A55540B
1A55540C
1A55540D
1A555410
1A555411
1A555412
1A555413
1A555414
1A555415
1A555416
1A555417
1A555418
1A555419
1A55541E
1A55541F
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
Amphenol Radsoc 8mm
2 Gnd Black
3 N/C
5 CAN L Black
6-9 N/C
10 12v Red 12V input.
13 N/C
14 White
15-19 N/C
26 N/C
2 x V216HC4 unknown
IC401 - Connects to pin 5 on the main processor, this appears to enable the 12v supply.
Using Multiple Packs
