External links
> CAN logs
LIM versions
SN | IEC 61851
J1772 (AC) |
61 35 9 380 352 | x | x | ? | BMW i3 | Nov 2015 | ||
61 35 9 494 498 | x | x | ? | BMW i3 | 2018? | x | |
61 35 9 470 199 | x | x | ? | BMW i3 | ? | ||
Mini cooper SE |
now |
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
X | Replacement Pins | 5-962885-1 |
X | Rubber Seal | 1-967067-1 |
1B-1 | - | |
1B-2 | - | |
1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
1B-4 | LOCK_MOT+ | Charge Inlet Lock Motor |
1B-5 | LOCK_MOT- | Charge Inlet Lock Motor |
1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
1B-10 | GND | Ground |
1B-11 | - | |
1B-12 | - | |
1B-13 | - | |
1B-14 | - | Internally connected to GND |
1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked) |
2B-1 | CP | Pilot (Charge Inlet) |
2B-2 | PP | Proxy (Charge Inlet) |
2B-3 | Jumper | Connected to Pin 4 |
2B-4 | Jumper | Connected to Pin 3 |
2B-5 | GND | Ground (Charge Inlet) |
2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
4B-2 | NEG_CONT+ | Negative HV Contactor Control |
4B-3 | POS_CONT- | Positive HV Contactor Control |
4B-4 | NEG_CONT- | Negative HV Contactor Control |
4B-5 | U_HV_DC | Charge Inlet DC Voltage (current input 3-20mA?) |
4B-6 | LED_RT | Red charge Status Light (12V RGB LED) |
4B-7 | LED_GN | Green charge Status Light (12V RGB LED) |
4B-8 | LED_BL | Blue charge Status Light (12V RGB LED) |
4B-9 | LED_GND | Charge Status Light Ground (common cathode of RGB LED) |
4B-10 | COV_MOT- | Charge Inlet Cover Motor (Not necessary) |
4B-11 | COV_MOT+ | Charge Inlet Cover Motor (Not necessary) |
4B-12 | COV_FB | Charge Inlet Cover Feedback (connect to GND to simulate open cover) |
Wiring Diagram
Required CAN messages
ID | Function | interval | Notes |
0x112 | BMS msg. | 10ms | |
0x1A1 | Vehicle speed | 20ms | |
0x3E9 | Main LIM control | 200ms | |
0x431 | Battery info | 200ms | needed but does not control anything |
0x03C | Vehicle status | 200ms | |
0x2A0 | Central locking | 200ms | |
0x397 | OBD | 200ms | |
0x3F9 | Engine info | 200ms | Rex? |
0x3A0 | Vehicle condition | 200ms | |
0x330 | Range info | 200ms | |
0x432 | BMS SoC | 200ms | |
0x51A | Network management | 200ms | |
0x540 | Network management 2 | 200ms | |
0x512 | Network management edme | 200ms | |
0x560 | Network management kombi | 200ms | |
0x510 | Network management zgw | 200ms | |
0x328 | Counter | 1s | |
0x3E8 | OBD reset | 1s | |
0x2FA | Lim DC charge command 3. | 1s | |
0x12F | Wake up | 100ms | |
0x2FC | Charge flap control | 100ms | |
0x2F1 | Lim DC charge command 2. | 100ms |
LIM peripheral boards
Large fast charging contactor control board
The LIM measures the current draw of the pos and neg fast charging contactors which makes it a bit harder to use large Gigavac contactors.
The easiest option is to place a small relais and a +/-20 watt 15 ohms (or slightly bigger) wire wound resistor in parallel to simulate the original contactor coil and drive a large Gigavac contactor with internal PWM economizer or dual coil.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Duosida inlet lock feedback
The i3 uses a quite expensive Phoenix CCS inlet and it would be nice to be able to use the cheaper Duosida CCS inlets.
The charge inlet lock should work with the Duosida lock as well but the feedback (1k unlocked, 11k locked) is a bit different which requires some additional resistors.
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
Observations
LIM board components
Chip | Description | Function | Datasheet |
Renesas V850E2/FG4 | 32-bit Single-Chip Microcontroller | main MCU | https://www.renesas.com/us/en/document/dst/data-sheet-v850e2fg4 |
Qualcomm QCA7000 | HomePlug® Green PHY, single chip solution | PLC Green PHY | https://openinverter.org/forum/download/file.php?id=9611 |
Infineon TLE 7263E | Integrated HS-CAN, LIN, LDO and HS Switch, System Basis Chip | CAN, 2xLDO, wake-up | https://docs.rs-online.com/db13/0900766b814d680b.pdf |
TI SN74LVC2T45-Q1 | Dual-Bit Dual Supply Transceiver with Configurable Voltage Translation | https://www.ti.com/lit/gpn/sn74lvc2t45-q1 | |
NXP 74LVC1T45 | Dual supply translating transceiver | https://datasheetspdf.com/pdf-file/648034/NXP/74LVC1T45/1 | |
STM L9951XP | Actuator driver | inlet lock motor | https://www.st.com/resource/en/datasheet/l9951.pdf |
STM TS321 | Low-Power Single Operational Amplifier | https://www.ti.com/lit/gpn/ts321 | |
TI LM2902 | Quadruple general-purpose operational amplifier | https://www.ti.com/lit/gpn/lm2902 | |
STM VNQ5E250AJ-E | Quad channel high-side driver with analog current sense | LEDs?, contactors? | https://www.st.com/resource/en/datasheet/vnq5e250aj-e.pdf |
