ZombieVerter VCU
What we have as of now is the openinverter wrapper with things like :
  • Throttle cal and mapping,
  • Precharge and contactor control,
  • Temp derating,
  • BMS limits,
  • for/rev/neutral control,
  • Graphing and monitoring,
  • Firmware updates via the web interface,
  • Cruise control,
  • Fuel gauge driver,
  • etc
So you've ordered your kit, first things first, watch the following video to assemble it.
Due to chip shortages (written summer 2021) the board isn't fully assembled so you will need to do some soldering, or take it to a local phone repair shop (or similar) who'll find soldering at this scale like playing with Duplo.
The enclosure kit links:
Enclosure Kit with Header, connector and pins :
Prewired connector with 3M leads :
Pin Out Diagram
VCU pinout diagram
Software
Supported OEM Hardware
  • Nissan Leaf Gen1/2/3 Inverter/ motor
  • nissan leaf gen 2 drive stack (inverter, dcdc, charger) gen 3 coming soon
  • Lexus GS450H inverter / gearbox via sync serial
  • Toyota Prius/Yaris/Auris Gen 3 inverters via sync serial
  • chevy volt HV water heater
  • BMW E46 CAN support
  • BMW E39 CAN support
  • BMW E65 CAN Support
  • CCS DC Fast Charge via BMW i3 LIM
