Toyota/Lexus MGR Rear Transaxle Motor
For conversion/project purposes the MGR is suitable for lighter models given the torque available or could potentially be used front and/or rear, and/or with a secondary motor.
As the motor was designed to be used occasionally as a rear motor, potential need for additional cooling dependent on the application
active forum thread: https://openinverter.org/forum/viewtopic.php?f=14&t=190
part numbers and there stated output:
Q210 (18 kW / 108 Nm)
Q211 (50 kW / 130 Mm or 139 Nm)
Q510 (5.0 kW or 5.3 Nm / 55 Nm)
Q610 (40 kW / 120 Nm)
these trans axles can be found on a variety of lexus and toyota vehicles:
- Alphard/Vellfire ATH20
- Alphard/Vellfire AYH30
- Estima AHR20
- Harrier MHU38
- Harrier AVU65
- Highlander MHU28
- Highlander MHU48
- Highlander GVU48
- Highlander GVU58
- Kluger MHU28
- Lexus RX400h MHU38
- Lexus RX450h GYL15
- Lexus RX450h GYL25
- Lexus NX300h AYZ15
- RAV4 AVA44
