External links
Forum discussion
> CAN logs
> I3 LIM CAN dbc1
BMW I3 HV components
LIM Connector Kit
LIM Compatible Contactors
LIM versions
LIM versions
SN IEC 61851
J1772 (AC)
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
Mini cooper SE
now
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1 / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545
Audi 7M0 973 119
TE 1-967616-1
X Replacement Pins 5-962885-1
X Rubber Seal 1-967067-1
LIM pinout
1B Pinout:
Pin # Function Description
1B-1 -
1B-2 -
1B-3 LED_M Lighting Charge Socket? (Not necessary)
1B-4 LOCK_MOT+ Charge Port Lock Motor
1B-5 LOCK_MOT- Charge Port Lock Motor
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 - Internally connected to GND
1B-16 LOCK_FB Charge Inlet Lock Feedback (1k unlocked, 11k locked)
2B Pinout:
2B-1 CP Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used!
2B-2 PP Proxy (charge port)
2B-5 GND Ground (charge port)
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-5 U_HV_DC Charge port DC Voltage (current input 3-20mA?)
4B-12 COV_FB Charge Port Cover Feedback (connect to GND to simulate open cover)
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
CAN communication
0x2FA Lim DC charge command 3. VCU 1s needed
0x328 Counter VCU 1s needed
Messages sent by LIM
0x29E CCS charger specs LIM
0x2EF Min available voltage from the ccs charger. LIM
0x2B2 Current and Votage as measured by the ccs charger LIM
0x3B4 EVSE info CP, PP & inlet voltage LIM
0x337 Inlet lock status LIM
LIM peripherals
isolated DC Voltage sense board by muehlpower
Fast charge contactor
TE EVC135 RELAY, SPST-NO, DM (# 2138011-1) is used as fast charge contactor in the KLE.
Available from EV Create https://www.evcreate.nl/shop/charging/contactor-matching-lim-ccs-charging-module-from-bmw-i3/
Large contactor control
If you want to use a larger contactor with PWM economizer or dual coil use a smal relais to drive it and place a 15 ohms resistor (with heat sink) in parallel to simulate the original contactor coil.
Each of the two 15 ohm resistor has to dissipate ~6W @ 13.4V, 50% PWM.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Charge port
DUOSIDA / MIDA CCS inlet
The original i3 type 1 charge port has 2.7 kΩ between PP and PE and no connection between CP and PE like J1772 describes.
The type 2 charge port used in Europe has probably 4.7 kΩ between PP and PE. (from Phoenix datasheet. Not confirmed!)
The CP communication is similar for US type 1 (1-phase) and EU type 2 (3-phase) charge ports but the PP circuit is a bit different and the lock mechanism is motorised for type 2 and manual for type 1.
Charge port lock
Only important for type 2 (3-phase) charge ports.
In the i3 a quite expensive Phoenix CCS charge port is used and it would be nice to be able to use the cheaper Duosida CCS charge ports.
CCS inlet lock
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
RGB LED
Charge control
The EVSE (charging station) shares it’s limits with PWM during IEC 61851/ J1772 AC charging or PLC during DIN 70121 or ISO 15118 CCS sessions but often the car can not handle the max available power of the charging station.
The actual battery voltage and battery current is needed by the LIM to check the respond of the charging station. In this setup the battery voltage and current gets measured by a Isabellenhütte IVT CAN bus sensor but those values could also be measured and shard on the CAN bus by the BMS. (CAN message 0x112)
Battery dependant charging current control
During (fast) charging a cell voltage and cell temperature dependant current limit is very important.
CCS inlet temperature sensors
Many CCS charge ports have DC and AC contact temperature sensors to avoid overheating if the contact resistance is high for some reason. The LIM has no temperature sensor inputs but the VCU / charge controller could be connected to the sensors (usually PT1000 or NTC) and reduce charging speed if the inlet gets too hot.
On board charger control
The LIM shares measured PP (charging cable) and CP (charging station) AC current limits in the CAN message 0x3B4 EVSE info.
If the on board charger accepts a AC current limit this value can be directly used but some chargers can only be controlled with DC current commands.
Since we don't know the actual AC current we can only estimate it with a fixed AC voltage and charger efficiency.
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
LIM logs
Observations
LIM board components
components
