VW Hybrid Battery Packs
Specification Overview
Passat GTE
Golf GTE
Pin | Colour | Notes | |
1 | Orange & Black | CAN H - Power Train | |
2 | Orange & Brown | CAN L - Power Train | |
3 | Blue | Airbag Control Module | |
4 | Purple & Yellow | Pilot line (In) | |
5 | Purple & Yellow | Coolant Value | |
6 | Red & Grey | 12v 30 amp | |
7 | Green | Coolant Pump | |
8 | Black & Green | 12v (IGN) | Fuse 49 on fuse holder C |
9 | Brown | Earth | |
10 | Red & Grey | 12v 30amp Fuse | |
11 | Black & Green | Pilot Line (out) | connects to the HV connector interconnect, then BMS master, then Pilot In |
12 | Black | Airbag Control Module | |
13 | Orange & Grey | CAN H - Hybrid | |
14 | Orange & Brown | CAN L - Hybrid |
E-Golf
Disassembly
Useful/Tools used:
- Electric Screwdriver
- Insulation Tape & Duct Tape
- Voltmeter
- Insulated shoes
- Work in the dry obviously
Golf GTE
E-Golf
BMS
ID | Data |
0x0BA | 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 |
0x0BA | 0x45 0x01 0x28 0x00 0x00 0x00 0x00 0x30 |
Battery Modules
Passat GTE
Golf GTE
Cooling
Contactors/Pre-Charge
Passat GTE
The Control box contains
- PEC 300A 450VDC fuse
- 1 x Contactor Control Board
Control board Interface Connector | |
The pinout is as follows:
Pin | Function | Wire Colour | Notes |
1 | Green | ||
2 | Green | ||
3 | |||
4 | Black/Grey | ||
5 | |||
6 | Brown | ||
7 | |||
8 | GND | Brown/Red | |
9 | GND | Brown/Red | |
10 | +12V | Red | |
11 | |||
12 | |||
13 | |||
14 | CANH | Orange/Blue | 120 OHM |
15 | CANL | Orange/Brown | 120 OHM |
16 | +12V | Yellow | |
17 | |||
18 | GND | Brown/Red |
Can output ...
CAN ID | Function | Notes |
000000BB | Shunt, Bytes 1 & 2 (16bit signed integer) | Multiply by 0.00625 to get amps |
18FED007 | ||
0000015B | ||
18FED008 | ||
18FED009 | Bytes 0 & 1 (16bit integer) | Possible Candidate Voltage @ Fuse |
18FED00A | ||
18FED003 | ||
18FED004 | ||
1A55545F | ||
16A95419 | ||
18FED006 | ||
18FED002 | ||
18FED005 |
BMS Control Module
000000BA | Module Wake up | |
1BFFDA1A | ||
1BFFDA19 | ||
1A55540A | ||
1A55540B | ||
1A55540C | ||
1A55540D | ||
1A555410 | ||
1A555411 | ||
1A555412 | ||
1A555413 | ||
1A555414 | ||
1A555415 | ||
1A555416 | ||
1A555417 | ||
1A555418 | ||
1A555419 | ||
1A55541E | ||
1A55541F |
Golf GTE
The control box contains a
- PEC 250A 450VDC fuse
- 2 x Panasonic AEV14012 M28 contactors https://docs.rs-online.com/6251/0900766b80e1fbed.pdf, yazaki 7283-1020 is the connector (would recommend a better contactor, I've welded one of these closed pretty easily)
- Current shunt.
PN: N 02 080 6121 002 (unconfirmed) |
Pin | Function | Wire Colour | Additional |
1 | Connects to battery case | Black | Ring terminal on the end, maybe for isolation test? Seems to output 5v. |
2 | Gnd | Black | |
3 | N/C | ||
4 | CAN H | White | 125ohm resistance between them. IC501 - TJA1042 |
5 | CAN L | Black | |
6-9 | N/C | ||
10 | 12v | Red | 12V input. |
11 | 12v | Red | 12V input. When supplied, IC204 begins outputting 5V |
12 | 12v ignition | White | Looks to be ignition 12v |
13 | N/C | ||
14 | 12v | White | Enables the 12v to the contactors. |
15-19 | N/C | ||
20 | Pre charge relay switched gnd | Black | Q409 is responsible for switching this to ground. |
21 | Contactor switched gnd | Black | Q408 is responsible for switching this to ground. |
22 | Contactor switched gnd | Black | Q408 is responsible for switching this to ground. |
23 | 12v for precharge relay | Yellow | Isolated from 12v supply, IC401 |
24 | 12v for contactor | Blue | Isolated from 12v supply, IC401 |
25 | 12v for contactor | Red | Isolated from 12v supply, IC401 |
26 | N/C |
2 x V216HC4 unknown
Using Multiple Packs
