ZombieVerter VCU
Revision as of 03:08, 9 December 2021 by Cgalpin (talk | contribs) (→‎Hardware)
What we have as of now is the openinverter wrapper with things like :
  • Throttle cal and mapping,
  • Precharge and contactor control,
  • Temp derating,
  • BMS limits,
  • for/rev/neutral control,
  • Graphing and monitoring,
  • Firmware updates via the web interface,
  • Cruise control,
  • Fuel gauge driver,
  • etc
The current list of parts to be fitted:
CONN1
IC10 = MCP25625T
IC14 = TJA1020 OR MCP2004
IC19 = NCV7356
IC20 = TJA1055T
IC21, 22 = AD5160
IC27, 28, 29 = FAN3122
And the positions on the V1 board.
The enclosure kit links
Enclosure Kit with Header, connector and pins :
Prewired connector with 3M leads (limited colors which will not match standard wire colouring conventions) :
Video Highlights
00:33 Warning and suggestion to go watch cat videos instead
01:06 Recap about the ZombieVerter VCU Build Part 1
03:04 How to get one
03:35 Design files currently require E10 Patreon membership/contribution if wanting to build your own
04:28 Components still requiring soldering
05:03 IC19 - 8 pin SOIC for single wire CAN (NCV7356)
06:00 IC10 - SPI CAN controller and transceiver (MCP25625T)
06:30 IC1,3,5,6,7,24,25,26 load driver mosfets (NCV8402)
07:20 Do you need these components?
08:40 Soldering begins - IC19
09:10 Soldering iron for SOIC parts
09:27 Applying flux using Damien's favorite Flux, UV80
10:34 Magnifier headset
13:27 Soldering MCP25625
15:55 Suggests getting an phone/computer repair shop to help out if needed
17:05 Using hot air gun to warm the board and position the chip
19:34 Soldering NCV8402s
23:28 Clean soldering with IPA Solvent
24:40 First power up test using bench power supply to limit current to a few hundred mA
26:47 60mA current draw with no wifi board
27:35 Wifi module
29:50 Power up test with wifi draws 90mA
30:25 Enclosure kit(s)
36:02 Soldering the PCB header (56 pin)
44:28 Installing in the enclosure
50:30 Cameo appearance by Gome cat
Video Highlights
00:34 Health warning and suggestion to go watch cat videos instead
01:42 Intro
03:20 Pinouts of the 56 pin connector
04:16 Pins 55,56 - Ground and +12V
04:49 Pins 53,54 - Reverse and Forward Direction. Apply +12V to the pin for the direction needed. Configurable in the web interface to flip these since direction is relative
07:32 Pins 52 - Start. Momentarily apply +12V to send a start signal
08:15 Pin 51 - HV Request. Apply +12v to precharge and bring up the high voltage system (and not the drive components)
09:05 Pin 50 - General Purpose 12V Input. Reserved for future use
09:23 Pin 49 - Brake Input. Connect to brake light switch to apply +12V signaling brakes are applied
10:15 Pins 45,46,47,48 - Throttle. +5V power, ground, and 1 or 2 hall effect sensor inputs
11:00 Pins 25,26,27,28 - 3 CAN bus interfaces. CAN EXT is for vehicle/body communication, CAN EXT 2 for the ISA shunt comms, CAN EXT 3 (with solderable jumpers to change modes) is for general purpose like charger, heater control
14:45 Pin 24 - Local Interface Network (LIN)
15:56 Pins 16,17,18,19,20,21,22,23 - Toyota Hybrid Inverter specific using async serial comms.
17:21 Pin 15 - Ignition T15 In. Apply +12V to turn Ignition on. Puts VCU in run mode
18:54 Pins 37,38,39,40,41,42 - Toyota Hybrid Transmission shift control
19:42 Pins 35,36 - POT1 & POT2. Digital potentiometer outputs to drive analog gauges (fuel, etc)
21:10 Pins 32,33,34 - Low Side (LS) switches for Inverter Power, Positive side Main Contactor, Precharge Contactor
23:21 Pin 31 - General Purpose +12V Output. LS switch for Negative side Main Contactor
24:01 Pins 12,13,14,29,30 - Toyota Hybrid System controls
25:24 Pins 10,11 - Digital to Analog Converter (DAC) 1 & 2. Reserved for future use - additional analog instruments etc.
26:33 Pins 8,9 - 0-5V Analog Inputs 1 & 2. Reserved for future use (ie not implemented yet)
27:06 Pins 5,6,7 - Pulse Width Modulation (PWM) 1-3 +12V output signals. Reserved for future use (ie not implemented yet)
27:56 Pins 3,4 - General Purpose +12V Outputs 2 & 3. Reserved for future use (ie not implemented yet)
28:29 Pins 1,2 - RS232 Rx/Tx Serial connection for alternation VCU communication (solder jumper configurable). Reserved for future expansion
30:11 CAN bus connected Isabellenhutte Huesler Shunt
38:45 Web Interface
44:10 How to perform a software update via the web interface using a precompiled binary
47:32 UI Features - Commands
52:50 UI Features - Update
53:30 UI Features - Parameters
1:11:32 UI Features - Spot Values
Will finish soon..
Installation
Pin Out Diagram
VCU pinout diagram
List of connections to system components (GS450 application)
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel. Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
Software
Various binaries can be found in the support thread, for example https://openinverter.org/forum/viewtopic.php?p=33379#p33379
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
If you are unable to build your own, use the stm32_vcu.bin that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
If you are unable to build your own, use the stm32_vcu.hex that Damien posted on 10/30/2021 in the ZombieVerter VCU Support thread.
Initializing an ISA Shunt
Supported OEM Hardware
  • Nissan Leaf Gen1/2/3 Inverter/ motor
  • nissan leaf gen 2 drive stack (inverter, dcdc, charger) gen 3 coming soon
