The LIM's are available new from BMW spare parts suppliers for € 240 but it is not confirmed if they come with firmware loaded or if they need to be programmed at the dealer.
External links
> CAN logs
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
| 1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
| X | Replacement Pins | 5-962885-1 |
| X | Rubber Seal | 1-967067-1 |
| 1B-1 | - | |
| 1B-2 | - | |
| 1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
| 1B-4 | LOCK_MOT+ | Charge Port Lock Motor |
| 1B-5 | LOCK_MOT- | Charge Port Lock Motor |
| 1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
| 1B-10 | GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | Internally connected to GND |
| 1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
| 1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked) |
| 2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! |
| 2B-2 | PP | Proxy (charge port) |
| 2B-3 | Jumper | Connected to Pin 4 |
| 2B-4 | Jumper | Connected to Pin 3 |
| 2B-5 | GND | Ground (charge port) |
| 2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
| 4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
| 4B-2 | NEG_CONT+ | Negative HV Contactor Control |
| 4B-3 | POS_CONT- | Positive HV Contactor Control |
| 4B-4 | NEG_CONT- | Negative HV Contactor Control |
| 4B-5 | U_HV_DC | Charge port DC Voltage (current input 3-20mA?) |
| 4B-10 | COV_MOT- | Charge Port Cover motor (Not necessary) |
| 4B-12 | COV_FB | Charge Port Cover Feedback (connect to GND to simulate open cover) |
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
Wiring notes
Bad pilot wiring can result in SLAC or other PLC communication problems.
Fast charge contactor
TE EVC135 RELAY, SPST-NO, DM (# 2138011-1) is used as fast charge contactor in the KLE.
Available from EV Create https://www.evcreate.nl/shop/charging/contactor-matching-lim-ccs-charging-module-from-bmw-i3/
Large contactor control
If you want to use a larger contactor with PWM economizer or dual coil use a smal relais to drive it and place a 15 ohms resistor (with heat sink) in parallel to simulate the original contactor coil.
Each of the two 15 ohm resistor has to dissipate ~6W @ 13.4V, 50% PWM.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Charge port
The original i3 type 1 charge port has 2.7 kΩ between PP and PE and no connection between CP and PE like J1772 describes.
The type 2 charge port used in Europe has probably 4.7 kΩ between PP and PE. (from Phoenix datasheet. Not confirmed!)
The CP communication is similar for US type 1 (1-phase) and EU type 2 (3-phase) charge ports but the PP circuit is different and the lock mechanism is motorised for type 2 and manual for type 1.
Charge port lock
Only important for type 2 (3-phase) charge ports.
In the i3 a quite expensive Phoenix CCS charge port is used and it would be nice to be able to use the cheaper Duosida CCS charge ports.
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
Charge control
The EVSE (charging station) shares it’s limits with PWM during IEC 61851/ J1772 AC charging or PLC during DIN 70121 or ISO 15118 CCS sessions but often the car can not handle the max available power of the charging station.
The actual battery voltage and battery current is needed by the LIM to check the respond of the charging station. In this setup the battery voltage and current gets measured by a Isabellenhütte IVT CAN bus sensor but those values could also be measured and shard on the CAN bus by the BMS. (CAN message 0x112)
Battery dependant charging current control
During (fast) charging a cell voltage and cell temperature dependant current limit is very important.
CCS inlet temperature sensors
Many CCS charge ports have DC and AC contact temperature sensors to avoid overheating if the contact resistance is high for some reason. The LIM has no temperature sensor inputs but the VCU / charge controller could be connected to the sensors (usually PT1000 or NTC) and reduce charging speed if the inlet gets too hot.
It is not possible to have two car side charge controllers connected to the pilot line. It is recommended to control the charger by CAN bus. If your charger needs the pilot you have to emulate it or switch the pilot over during AC charging.
If the on board charger accepts a AC current limit this value can be directly used but some chargers can only be controlled with DC current commands.
Since we don't know the actual AC current we can only estimate it with a fixed AC voltage and charger efficiency.
CAN communication
| 0x112 | BMS msg. | VCU or BMS | 10ms | could also be sent by BMS |
| 0x2FC | Charge flap control | VCU | 100ms | needed (constant values work) |
| 0x03C | Vehicle status | VCU | 200ms | (constant values) needed? |
| 0x1A1 | Vehicle speed | VCU | 20ms | (constant values) 10ms works needed? |
| 0x2A0 | Central locking | VCU | 200ms | (constant values) needed? |
| 0x397 | OBD | VCU | 200ms | (constant values) needed? |
| 0x3F9 | Engine info | VCU | 200ms | (constant values) needed? |
| 0x3A0 | Vehicle condition | VCU | 200ms | (constant values) needed? |
| 0x330 | Range info | VCU | 200ms | (constant values) needed? |
| 0x512 | Network management edme | VCU | 200ms | (constant values) needed? |
| 0x560 | Network management kombi | VCU | 200ms | (constant values) needed? |
| 0x3E8 | OBD reset | VCU | 1s | (constant values) needed? |
| Messages sent by LIM | ||||
| 0x2EF | Min available voltage from the ccs charger. | LIM | ||
| 0x2B2 | Current and Votage as measured by the ccs charger | LIM | ||
| 0x3B4 | EVSE info CP, PP & inlet voltage | LIM | ||
LIM logs
Observations
LIM hardware
LIM versions
| SN | IEC 61851
J1772 (AC) |
Mini cooper SE |
now |
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Chips on the LIM board
Charging protocols
Signaling circuit
AC charging
Some new charging stations support AC charging with ISO 15118 high level protocol as well. But it is not confirmed which versions of the LIM support it.
By default the the EVSE (charging station) outputs +12V on the CP pin, this when connected to an EV will get reduced to 9V because of a load resistor present in the Electric Vehicle, this signals the EVSE that the connector has been plugged into a EV. After this the EVSE will send a 1khz +12V to ‐12V square wave (PWM signal) and the duty cycle value corresponding to the maximum current it could deliver. If the EV is okay with that value of current then it performs a handshake by changing the load resistance and dropping the PWM voltage to 6V after which the charging begins.
In IEC61851 where untethered charging stations are allowed the PP pin is used to detect the maximum power rating of the cable.
In the US with J1772 where charging stations need to be tethered the PP pin is used to detect if the manual unlocking mechanisme is pressed to stop the current flow before the plug is removed.
more information https://en.wikipedia.org/wiki/SAE_J1772
CCS DC charging
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
