Revision as of 22:14, 9 June 2022 by Asavage (talk | contribs) (→‎Charge port lock: Moved inline citation for connector shell fitment down to the specific shell part number reference.)
External links
Forum discussion
> CAN logs
> I3 LIM CAN dbc1
BMW I3 HV components
LIM Connector Kit
LIM Compatible Contactors
Connectors and Pinouts
Connector Key (left to right)
Audi 4E0 972 713
TE 1534152-1 / 1534151-1
Audi 4F0 972 708
TE 1-1534229-1
1B 16 Pin Connector Hirschmann 805-587-545
Audi 7M0 973 119
TE 1-967616-1
X Replacement Pins 5-962885-1
X Rubber Seal 1-967067-1
LIM pinout
1B Pinout:
Pin # Function Description
1B-1 -
1B-2 -
1B-3 LED_M Lighting Charge Socket? (Not necessary)
1B-4 LOCK_MOT+ Charge Port Lock Motor
1B-5 LOCK_MOT- Charge Port Lock Motor
1B-6 CAN_H Powertrain CAN
1B-7 CAN_L Powertrain CAN
1B-9 VCC Constant Power +12V
1B-10 GND Ground
1B-11 -
1B-12 -
1B-13 -
1B-14 - Internally connected to GND
1B-16 LOCK_FB Charge Inlet Lock Feedback (1k unlocked, 11k locked)
2B Pinout:
2B-1 CP Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used!
2B-2 PP Proxy (charge port)
2B-5 GND Ground (charge port)
3B Pinout:
- N/A (for CHAdeMO only)
4B Pinout:
4B-5 U_HV_DC Charge port DC Voltage (current input 3-20mA?)
4B-12 COV_FB Charge Port Cover Feedback (connect to GND to simulate open cover)
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
Wiring notes
Fast charge contactor
Larger contactor control
If you want to use larger contactors with PWM economizer or dual coil, use small relays to drive them and place a 15 ohms resistor (with heat sink) in parallel with each to simulate the original contactor coil's impedance.
Charge port
DUOSIDA / MIDA CCS inlet
The CP communication is similar for US Type 1 (1-phase) and EU Type 2 (3-phase) charge ports, but the PP circuit is different and the lock mechanism is motorised for Type 2 and manual for Type 1.
Charge port lock
Only important for Type 2 (3-phase) charge ports.
In the BMW i3 a quite expensive Phoenix CCS charge port is used and it would be nice to be able to use the cheaper Duosida CCS charge ports.
RGB charge indication light
RGB LED
Charge control
CCS inlet temperature sensors
CAN communication
0x328 Counter VCU 1s needed
Messages sent by LIM
0x29E CCS charger specs LIM
0x337 Inlet lock status LIM
LIM logs
Observations
LIM hardware
LIM versions
Only "LIM_AC_DCO" versions work for CCS. Look for both "LIM_AC_DCO" and a MAC address on the label! If no MAC, the LIM is either AC-only or AC + CHAdeMO, and not useful for CCS.
LIM versions
SN IEC 61851
J1772 (AC)
61 35 9 346 827 x x BMW i3
61 35 9 346 820 x x BMW i3
Mini cooper SE
now
Power Limits
Chips on the LIM board
components
Charging protocols
Signaling circuit
AC charging
CCS DC charging
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications, but since most of the protocols used are similar it has comparable sequence diagrams, with descriptions for normal start up, normal shutdown, DC supply-initiated emergency stop and EV-initiated emergency stop.
