Mitsubishi Outlander DCDC OBC
Revision as of 00:47, 7 January 2022 by Crasbe (talk | contribs) (Added categories to the page to allow for better navigation and removed "Links" section.)
* Length 370mm
* Width 270mm
* Height 150mm
DC-DC Converter
To start the DC-DC converter, first to apply 12V to pin 7 and GND to pin 10. You also need to have its casing connected to common GND.
Pinout as as follows:
  • Pin 1 (Orange) NC on outlander
  • Pin 2 NC on outlander
  • Pin 3 (Blue) NC on outlander
  • Pin 4 DC SW (enables the DC:DC converter)
  • Pin 5 CHIN (Serial protocol to EV Remote wifi module)
  • Pin 6 CAN H (Black)
  • Pin 7 Sense line for DC to DC converter
  • Pin 8 IGCT main power to charger
  • Pin 9 Control Pilot from charging cable
  • Pin 10 GND
  • Pin 11 NC
  • Pin 12 CHOT (Serial protocol to EV Remote wifi module)
  • Pin 13 CAN L (Red)
Charge Control
CANBus Messages
Outlander Charger DBC File
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1 but that is completely ignored
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v)
- B5 = Temperature 2		(starts at -40degC, +1degC/bit)
- B6 = Temperature 3		(starts at -40degC, +1degC/bit)
- B7 = Statusbyte 		(h20=standby, h21=error, h22=in operation)
-  - bit0(LSB) = Error
-  - bit1	= In Operation
-  - bit3      =
-  - bit4      =
-  - bit5      = Ready
-  - bit6	=
-  - bit7(MSB) =
0x389
- B6 = Charger Supply Current x 10
0x38A
- B0 = temp x 2?
- B1 = temp x 2?
