Ford Ranger TIM Controller
Revision as of 22:29, 28 June 2022 by Crasbe (talk | contribs) (Crasbe moved page Ford ranger ev board to Ford Ranger TIM Controller: Make the title consistent with the naming scheme)
The new ECU for the Ford Ranger TIM (traction inverter module) is based on the openinverter design. It uses the original TIM's power eletronics, IGBT drivers, current sensors and voltage sensors.
So most of the information for the openinverter V2 board is also relevant for the Ranger inverter.
Just started to make the "Ranger TIM" Wiki, so most of the information is at the openinverter forum Ford Ranger section
Schematics and connector pinout
joromy_tim_w_GND_fill_15b - Schematic.pdf
TIM connector C4998
Name (New TIM) Circuit (Old TIM) Function (New TIM)
1 NC NC
2 MTMP- 3708 (BN) Motor Temp sensor Motor Temp sensor Input -
3 DIS_DRV 3404 (YE) Chg cord plugged in Charge cable plugged in (12V, Motor PWM inhibit when low)
4 USART_TX 3017 (DG/WH) SIADIS RXD Serial comm. Or WiFi module
5 CAN_H 914 (TN/OG) J1850 bus plus CAN BUS
6 STOP_RLY 3235 (YE/LG) Stop lamp RLY Stop signal when regen (Active, GND. Inactive, Z)
7 VSS_OUT 679 (GY/BK) Vehicle speed signal Vehicle Speed Signal, to IAA and Power steering (12v PWM)
8 SIG_MAIN_C 3986 (DG) Main contactor DC contactor and oil pump relay (Active, GND. Inactive, Z)
9 12V_ALL_T 276 (BN) Power hot all time 12V all time (used for relay protection diode)
10 12V_RUN_START 640 (RD/YE) Power run/start 12v in RUN, START, ACC
11 MTMP+ 3757 (BK/WH) Motor Temp sensor Motor Temp sensor Input +
12 NC NC
13 3.3V_USART 3018 (WH) SIADIS d/l Serial comm. Or WiFi module
14 USART_RX 3016 (LG/BK) SIADIS TXD Serial comm. Or WiFi module
15 CAN_L 915 (PK/LB) J1850 bus minus CAN BUS
16 NC NC
17 NC NC
18 PRECHG_RLY 3991 (TN) Precharge RLY contr Precharge relay (Active, GND. Inactive, Z)
19 12V_ALL_T 276 (BN) Power hot all time 12V all time (used for relay protection diode)
20 12V_RUN_START 640 (RD/YE) Power run/start 12v in RUN, START (this will power up the inverter ECU)
21 NC NC
22 NC NC
23 GND_USART 3019 (GY/BK) SIADIS GND Serial comm. Or WiFi module
24 NC NC
25 NC NC
26 SIG_VSS_B 3701 (DB/WH) VSS B signal Encoder channel B
27 NC NC
28 NC NC
29 GND 3233 (BK/LB) GND GND
30 5V_VSS 3707 (OG) VSS +12 ref Encoder PWR +5V
31 CH_GND 57 (BK) Chassis GND Chassis GND
32 NC NC
33 NC NC
34 NC NC
35 EMCY_PWR 3997 (DG) Emergency PWR Off EPO Emergency Power Off (Active, Z. Inactive, 12V)
36 SIG_VSS_A 3700 (LB/RD) VSS A signal Encoder channel A
37 OIL_P_RLY 3005 (VT/LG) Oil pump RLY DC contactor and oil pump relay (Active, GND. Inactive, Z)
38 NC NC
39 GND 3233 (BK/LB) GND GND
40 GND_VSS 3659 (BK/PK) VSS GND Encoder GND
TIM connector C4999
1 NC 224 (TN/WH) ABS fault in ABS_FAULT (Active, GND. Inactive, 12V)
2 NC NC
3 GND_APS1 3837 (GY/YE) APS1 GND Trottle pot GND
4 SIG_APS1 3835 (YE/WH) APS1 Signal Trottle pot signal
5 5V_APS1 3836 (YE/LB) APS1 +5V Trottle pot PWR
6 ABS_ACT_IN 491 (OG/LB) ABS active in ABS input. Limit torque and regen. (Active, 12V. Inactive, GND)
7 GND_DIR_SW 3500 (RD) DTR TR1 Signal Gear switch GND
8 SW_START 33 (WH/PK) PWR (Hot in start) Key in start pos (Active, 12V)
9 SW_CRUISE 3011 (BK/OG) APS2 GND Cruise control switch/button (Active, 12V)
10 SIG_PWR_L 3012 (WH) APS2  Signal BMS input. Limit torque and regen. (Active, 12V. Inactive, Z)
11 SIG_OIL_PS 3010 (TN) APS2 +5V Analog/lamp oil P indicator (0-5V/Active, GND. Inactive, Z)
12 OIL_P_SENS 3605 DB/WH) Oil P switch Analog/switch oil P sensor (0-5V/Active, GND. Inactive, Z)
13 NC 3503 (YE) DTR TR4 Signal Goes to DTR switch and "old" BCM C1987 pin 18
14 SW_BRAKE 810 (RD/LG) Brake pedal sw Brake pedal switch (Active, 12V)
15 NC 3014 (BK/WH) APS3 GND Spare wire
16 5V_OIL_PS 3015 (WH/RD) APS3 Signal Only if analog 5V oil pressure sensor is used
17 ERROR_OUT 3013 (GY/BK) APS3 +5V Error output (open collector 0.5A)
18 SW_REV 3502 (DG) DTR TR3A Signal Cut at DTR switch pin3 and tie to pin11 140 (BK/PK)
19 NC NC
20 NC 3501 (DB) DTR TR2 Signal Goes to DTR switch and "old" BCM C1987 pin 17
21 GND_BRK_PS 3601 (WH/RD) Brake P sens Brake pressure sensor GND
22 PS_BRAKE 3600 (RD/WH) Brake P sens Brake pressure sensor signal ~ 0.5-5V
23 5V_BRK_PS 3603 (RD) Brake P sens Brake pressure sensor PWR
24 SW_FWD 3504 (BK/OG) DTR GND Gear switch (Active, Z. Inactive, GND)
Modifications to original wiring
MODIFICATIONS: (Please read the Ford Ranger treads, for details)
Hardware installation
Where to buy
