VAG MLBevo MQB Chargers
Revision as of 21:29, 30 October 2022 by Vfr800 (talk | contribs) (→‎Pinouts)
MEB Chargers
There are many different variants of MEB chargers with a wide range of potential power outputs.
3.6kW: 5QE915685 and 5QE915682
11kW and 22kW: - 5QE915684J, 5QE915684AD, 5QE915684A - From Audi e-Tron, single AC input, coolant connections at opposite end to electrical connections -
5QE915684BJ - I think it's from the Audi e-Tron, single AC input, coolant connections on the right side when looking from the connector end -
5QE915684BC, 5QE915684BK - From Porsche Taycan, dual AC input, coolant connections on the right side when looking from the connector end
Pinouts
Golf PHEV Pinout
Pin Function
1 Terminal 30 (permanent 12V)
2
3
4 Charge Port RGB LED +12v o/p
5 Charge Port RGB LED +12v o/p
6
7
8
9 Powertrain CAN bus, high
10 Powertrain CAN bus, low
11 Hybrid CAN bus, high
12 Hybrid CAN bus, low
13 HVIL IN
14
15 HVIL OUT
16 Lock drive +. Drive to 12v to close lock.
17 Lock Drive – Drive to 12v to open lock
18 Lock feedback. 1K fully locked ur unlocked. 11K in travel.
19 Lock feedback. 1K fully locked ur unlocked. 11K in travel.
20
21 Immediate charge buttons
22 Charge Port RGB LED +12v o/p
23 Control Pilot (CP)
24 Plug Present (PP)
25 Immediate charge buttons
26
27 Temperature sender for charging socket. 1067R at approx 15C
28 Temperature sender for charging socket. 1067R at approx 15C
29
30
31 Charge port door lock actuator
32 Charge port door lock actuator
33 Charge port door lock actuator
34 Charge port door lock actuator
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51 Immediate charge buttons
52
53
54
55
56
57
58
59
60 Terminal 31 (Ground)
Seat Mii/EGolf Pinout
Pin Function 1 Terminal 30 2 3 4 5 6 7 8 9 Powertrain CAN bus, high 10 Powertrain CAN bus, low 11 Hybrid CAN bus, high 12 Hybrid CAN bus, low 13 HVIL IN 14 15 HVIL OUT 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 Terminal 31
