Lexus GS450h Drivetrain
Revision as of 20:53, 2 January 2023 by Compassion (talk | contribs) (Adding Sumitomo Transmission Connectors)
  • Two high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps. [1]
Weight: 40 lbs
Buck/Boost Converter
Transmission
It is a good idea to replace the two bearings in the electric oil pump before fitting a used transmission. There is a guide here[4]. Bearing part numbers are 61900-2Z and 608-2Z, you will need one of each.
GS450h shift position sensor
Oil Pump
Overview and location
Wiring and control
GS450h oil pump controller
Pinouts, schematics and notes
Gasket (1) 35142-30010 $14
Wiring Harness Connectors
Inverter Connectors
OEM
Connector Part No. Location
90980–12630
Black connector on the side of the inverter. This connector is not sold anywhere to our knowledge.
Alternatives
Molex MX123 series
Image Part No. Item Quantity
064320-1301 CMC wire cap 1
064323-1039 CP terminal 4
064322-1039 CP terminal 32
064325-1010 CMC plug 8
064325-1023 CMC plug 4
Assembly Instructions
Instructions on how to assemble the MX123 connector can be found here [5].
(0.64)
8100-3456 (Gold)
8240-0288 (Gold)
Shift Lever Position Sensor (E80) Toyota 90980-12362 Sumitomo 90980-12362 TS 025 Series (0.64)
Female - 7 20-22 AWG /
.3-.5 mm2
16-18 AWG /
.85-1.25 mm2
7116-4029-08 (Gold)
TS 090II Sealed Series
2.3 II
(6mm LIF variant)
MG1 & MG2 Resolver(s) (E81 & E82) Toyota 90980-12520 Sumitomo 6189-1240 TS 025 Series (0.64) Female - 8 .13 mm2 / 26 AWG .22-.35 mm2 / 24-22 AWG .5 mm2 / 20 AWG Two connectors located on the left side of the transmission by the bell housing.
8100-3456 (Gold)
8240-0288 (Gold)
TS 025 Series Seal Plug
Wire Insulation Dia. Color Part Number Color Part No
2.0-2.2 mm (.079-.087 in) Grey 7158-3007-10
Control Schemes
ZombieVerter VCU
