VCU Comparison
Revision as of 10:54, 18 January 2023 by Celeron55 (talk | contribs)
Caption text
Comparison ZombieVerter GEVCU7 Mini-E-VCU iPDM56v1.1
Open source software Yes Yes Yes Yes
Open source hardware Yes No Yes No
Schematics and board layouts available Yes No Yes Yes
Example Example Example Example Example
Draft by celeron55
TODO:
- Add outlander vcu - Add johu's vcu - Add other VCUs that have been used by people on the openinverter forums - Fill in missing info - Add links
VCU Comparison:
- Open source software
   - ipdm: Yes
   - zombie: Yes
   - GEVCU7: Yes
- Open source hardware
   - ipdm: No
   - zombie: Yes
   - GEVCU7: No
- Schematics and board layouts available:
   - ipdm: Yes
   - zombie: Yes
   - GEVCU7: No
- Price (roughly inc. VAT + shipping + enclosure):
   - ipdm: 135€
   - zombie: 350€
   - gevcu7: 1500€
- In stock:
   - ipdm: 2023-02
   - zombie: Yes
   - gevcu7: Yes
- External connector pins:
   - ipdm, zombie: 56
- External connector pin size range, A:
   - ipdm, zombie: 5A?
- Primary use case
   * ipdm: Power distribution, I/O extension
   * zombie: Inverter control including Toyota
   * GEVCU: CAN inverter control, logging
- Software platform:
   - ipdm: Arduino
   - zombie: libopeninv
   - GEVCU7: Arduino
- External configuration interface:
   - ipdm: USB serial, TTL serial
   - zombie: Wifi
   - gevcu7: Bluetooth, Wifi, USB serial
- Configuration format:
   - ipdm: Arduino sketch
   - zombie: Parameter list
- Out-of-the box supported inverter brands:
   - ipdm: None
   - zombie: OpenInverter, Nissan, Toyota, Lexus, Outlander?
   - gevcu7: DMOC, CODA, Brusa, PM100, C300
- MCU family:
   - ipdm: AVR
   - zombie: STM32F1
   - gevcu7: iMXRT1062
- Flash
   - ipdm: 32kB
   - gevcu7: 16MB
- RAM:
   - ipdm: 2kB
   - gevcu7: 1024kB
- Supply voltage range:
   - ipdm: 8...16V
- Standby mode description:
   - ipdm: 6mA running Arduino sketch at slow clock speed
- Buses:
   - ipdm: 2x CAN
   - zombie: 3x CAN, 1x Toyota, 1x LIN, 1x RS232?
   - gevcu7: 3x CAN
- Number of inputs:
   - ipdm: 14
   - zombie: 10?
   - gecvu7: 12
- Analog inputs (including throttle and external NTC channels):
   - ipdm: 5
   - zombie: 6?
   - gevcu7: 8
- PWM inputs:
   - ipdm: 2
- Additional special inputs:
   - ipdm: 12V battery voltage monitoring
- Signal PWM outputs:
   - ipdm: 0
   - zombie: 1?
- Power PWM outputs (low / high side, A):
   - ipdm: 4x L 3A
   - zombie: 3x L ?A
- Low-side power outputs, total A / count:
   - ipdm: 20A / 10x
   - zombie: 5A (limited by ground pin) / 9x?
   - gevcu7: 16A / 8x
- High-side power outputs, total A / count
   - ipdm: 15A / 10x
- Analog outputs:
   - ipdm: 2x 0-500mA low side slow
   - zombie: 2x AC coupled, 2x digital resistors
- Power outputs readable as inputs:
   - ipdm: 8
- Simultaneous customizable jumpers/resistors:
   - ipdm: 32
   - zombie: 0?
