Mitsubishi Outlander DCDC OBC
* Length 370mm * Width 270mm * Height 150mm
Internals:
Bottom | Top |
DC-DC Converter
*at about 397v the dcdc appears to stop operating via the enable lines. currently untested if it continues via can. [3]
Signal Connector
Pin on 13-pin Connector | Pin on Internal Connector | Color | Color from Schematic | Name | Function |
1 | Orange | NC | Not Connected | ||
2 | NC | Not Connected | |||
3 | Blue | NC | Not Connected | ||
4 | Violet-Green | DC SW | Enable DC/DC Converter | ||
5 | Pink-Green | CHIN | Serial Protocol to EV Remote WiFi Module | ||
6 | Black | Black-Blue | CAN H | CAN High | |
7 | Grey | Sense | Sense for DC/DC Converter (via shared 7.5A fuse) | ||
8 | Light Green | IGCT | Main +12V Power Supply (via shared 7.5A fuse) | ||
9 | Blue | CP | Control Pilot from Charge Port | ||
10 | Black | GND | Ground | ||
11 | NC | Not Connected | |||
12 | Brown-Red / Yellow-Black | CHOT | Serial Protocol to EV Remote WiFi Module | ||
13 | Red | Red-Blue | CAN L | CAN Low | |
Note: Although the above pin numbers match the Mitsubishi wiring diagram the numbers marked on the connectors are reversed for each row. Pin 1 is CAN H (Black), pin 6 is NC (orange), pin 7 is CAN L (red ) and pin 13 Sense ( green ).
External Connector
Internal Connector
In case the Charger doesn't come with the signal pigtail (which it usually does), the internal signal connector is from the Hirose GT8E series[6], specifically the Hirose GT8E-12DS-HU[7] with Hirose GT8E-2022SCF[8] pins.
The External to Internal wiring harness is as follows:
Internal Connector (Black) | External Connector (Grey) | |||
Pin | Wire Colour | Pin | Function (If Known) | |
1 | grey | 4 | DC SW - Enable DC/DC Converter | |
2 | blue | 3 | NC | |
3 | black | 6 | CAN H -CAN High | |
4 | black | 10 | GND – Ground | |
5 | yellow | 8 | IGCT – Main +12V Power Supply (via shared 7.5A fuse) | |
6 | green | 7 | Sense - Sense for DC/DC Converter (via shared 7.5A fuse) | |
7 | light blue | 5 | CHIN - Serial Protocol to EV Remote WiFi Module | |
8 | NC | 11 | NC | |
9 | orange | 1 | NC | |
10 | red | 13 | CAN L – CAN Low | |
11 | purple | 12 | CHOT – Serial Protocol to EV Remote WiFi Module | |
12 | white | 9 | CP – Control Pilot from Charge Port |
AC Power Connector
The AC power connector is Yazaki 7283-7350-30 / Toyota 90980-11413[9].
+12V DC Connector
The thread size of the +12V stud of the DC/DC converter is M8.
Charge Control
CANBus Messages
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The charger reads this value only once. To update it, you have to first power cycle the 12V line "Pin 8 IGCT main power to charger". The requested current should be limited to 12A, going above this results in strange current delivery.
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v) - Byte 2 = Current in amps x 10
- B0+B1 = 12V Battery voltage (h04DC=12,45V -> 0,01V/bit) - B2+B3 = 12V Supply current (H53=8,3A -> 0,1A/bit) - B4 = Temperature 1 (starts at -40degC, +1degC/bit) - B5 = Temperature 2 (starts at -40degC, +1degC/bit) - B6 = Temperature 3 (starts at -40degC, +1degC/bit) - B7 = Statusbyte (h20=standby, h21=error, h22=in operation) - - bit0(LSB) = Error - - bit1 = In Operation - - bit3 = - - bit4 = - - bit5 = Ready - - bit6 = - - bit7(MSB) =
0x389
- B0 = Battery Voltage (as seen by the charger), needs to be scaled x 2, so can represent up to 255*2V; used to monitor battery during charge - B1 = Charger supply voltage, no scaling needed - B6 = Charger Supply Current x 10
0x38A
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming;
if (Can0.available() > 0) {
Can0.read(incoming);
if (incoming.id == 0x389) {
voltage = incoming.data.bytes[0];
Ctemp = incoming.data.bytes[4];
if (incoming.id == 0x377){
aux1 = incoming.data.bytes[0];
aux2 = incoming.data.bytes[1];
auxvoltage = ((aux1 * 256) + aux2); //recalculate two bit voltage value
void sendCANframeA() {
outframe.id = 0x286; // Set our transmission address ID
outframe.rtr=1; //No request
outframe.data.bytes[0]=0x28;
if(voltage < 193) { // if Charger senses less than 386V
outframe.data.bytes[2]=0x1E;
else { //any other case
outframe.data.bytes[2]=0x00;
outframe.data.bytes[4]=0x00;
outframe.data.bytes[5]=0x00;
outframe.data.bytes[6]=0x0A;
outframe.data.bytes[7]=0x00;
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off
auxState = true; // set the flag to true
elapsedtime = millis();
DCDCauxcharge();
void DCDCauxcharge() {
if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V
digitalWrite(DCDC_active, HIGH);
if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min
auxState = false;
else { // if auxvoltage is OK
auxState = false; // turn off DCDC_active relay
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/2019/index_M1.htm (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E05AC00ENG.pdf (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E05BC00ENG.pdf (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E05CC00ENG.pdf (Backup: Web Archive)
- ↑ http://mmc-manuals.ru/manuals/outlander_phev/online/Service_Manual_2014/img/90/HKAE0E06AC00ENG.pdf (Backup: Web Archive)
- ↑ https://www.hirose.com/de/product/document?clcode=CL0758-0051-6-00&productname=GT8E-12DS-HU&series=GT8E&documenttype=Catalog&lang=de&documentid=D49379_en (Backup: Web Archive)
- ↑ https://www.mouser.de/ProductDetail/798-GT8E-12DS-HU
- ↑ https://www.mouser.de/ProductDetail/798-GT8E-2022SCF
- ↑ https://www.auto-click.co.uk/7283-7350-30?search=90980-11413 (Backup: Web Archive)
