'Raven' Model 3 based Front Drive Unit
Revision as of 11:52, 13 July 2023 by Mitchy (talk | contribs) (Created)
The Model S/X currently offers the 'Raven' Drivetrain...
Base difference with this drivetrain is the addition of a new Front Drive Unit. This new front drive unit is, at it's core, a repackaged M3 Performance Drive Unit.
The Repackaging means that it generally will fit in similar cases where the older Front SDU will fit.
Quick Facts:
  • Permanent Magnet Rotor
  • Uses Model 3 based inverter, confirmed same PCB # as other M3 based units
  • At least one unit confirmed to be shipped with the 24 SiCFET inverter (800A '980' inverter)
  • Similar Shared design with the Plaid Front Drive Unit.
    • Raven Part#: 1478000-01
    • Plaid Part#: 1478100-01 (Reference: E-Bay - Seller reference from Disassembled Plaid DriveTrain)
3D Scan Data:
- Underway, Link to be posted to GrabCad
Part Numbers:
  • Full Assembly:
    • Motor #: 1478000-01
  • Inverter:
    • Housing: P1117428-00-C
    • Casing: 1085693-00-F
    • PCB: 1078289
    • Part#: 186592-13-H
