BMW i3 Inverter
Revision as of 22:50, 1 November 2023 by CJW (talk | contribs) (Added description of resolver connector and cables from forum posts.)
BMW I3 inverter
BMW I3 inverter
Pinout for Ampseal Plug
Pin No Assigniment Description
1 12V
2 BRAKE_IN
3 PRECHARGE_OUT
4 CANL
5 CANH
6 DCSW_OUT
7 FORWARD_IN
8 REVERSE_IN
9 5V (OUT)
10 RESOLVER_S2/ENCODER_A Sin Low (blue)
11 GND
12 RESOLVER_S1 Sin Hi (red)
13 THROTTLE1
14 THROTTLE2
15 RESOLVER_R1 Excitation Hi (yellow)
16 RESOLVER_S3/ENCODER_B Cos Hi (white)
17 MTEMP+ (blue)
18 MTEMP- (grey)
19 RESOLVER_S4 Cos Low (brown)
20 EMCYSTOP_IN
21 GND
22 RESOLVER_R2 Excitation Low (green)
23 START_IN
Note: colours in description column above are for the BMW cables coming from the motor.
There are 2 variants of the i3. one with the REX and one with out.
the REX variant has a additional 25kw inverter to run the onboard generator.
Gate Driver Board Pin out
Pin No I/O Description Notes Pin No I/O Description Notes
1 21 GND Switching Mosfets ?
2 I 32V in 22 GND Switching Mosfets ?
3 I 32V in 23
4 I IGBT A HI 24
5 I IGBT A LOW 25
6 I CS (ADC) 26 GND IGBT Driver ground
7 I SDI 27 GND IGBT Driver ground
8 I SDO 28 GND IGBT Driver ground
9 I SCK 29 GND IGBT Driver ground
10 I IGBT B HI 30 GND IGBT Driver ground
11 I IGBT B LOW 31 GND IGBT Driver ground
12 I IGBT C HI 32 GND IGBT Driver ground
13 I IGBT C LOW 33 5V IGBT Driver Power
14 34 5V IGBT Driver Power
15 35 I IGBT PSU 12V on
16 O IGBT DRIVER UVW Upper Ready 36 O IGBT Driver Fault
17 O IGBT DRIVER UVW Lower Ready 37 I 5V LEM Current sensor Power
18 O Current Sense C Signal 38 GND Current sensor Ground
19 O Current Sense B Signal 39 GND Current sensor Ground
20 O Current Sense A Signal 40 GND Current sensor Ground
Motor Resolver & Temperature Sensors
12-pin connector from the motor is an ERNI MiniBridge vertical SMT, part number 294920
