Talk:CCS32Clara
Add: Section on Supported Chargers/Test Results
For Context GitHub Pull Request: https://github.com/uhi22/ccs32clara/pull/4#issue-2045351022
Proposed added Section if PR gets accepted might look something like this:
Supported Chargers
Clara + Focci has been tested successfully at various chargers.
You can find the raw test results documented on GitHub. [will be added soon]
Currently there are no official supported chargers. (This doesn´t mean Clara + Focci) is not working, just that there havent been sufficient tests yet).
Conflicting of use of udcdivider
udcdivider is listed as having differing (?) functions in two places.
1) Parameters "Division factor from ADC digits to V of external voltage measurement board"
2) Making Clara talk CHAdeMO on the CAN side "some dummy item as the important bit is in the Offset field: the version. In this case I signal non-existent CDM version 10."
Can both co-exist?
