Lexus GS450h Drivetrain
The Lexus GS450h VCU is an open source project to repurpose 2006-2012 Lexus GS450h inverters for DIY EV use. It consists of a circuit board and programming that communicates with the original logic board in the inverter and allows independent control of it without communicating with a GS450h ECU.
Note that the Toyota Camry hybrid (US market) uses a similar inverter with the same logic board, which is functionally identical to the GS450h unit.
GS450h Inverter
- 2 high power inverters, for the 2 motors MG1 capable of handling X(?) amps, and MG2 capable of handling Y(?) amps.
- A boost module to boost the 288v battery pack up to 650v
GS450h Converter
A buck/boost converter lives within the inverter housing, originally this is used to step up the 288V battery pack in the GS450h to the 650V for use in the inverter. For those using a 600+V battery pack, this converter can be used to step the voltage down to a more reasonable level to interface with charfgers, DCDC converters, heaters, AC compressors, and other components which can be found in "regular" EV's (Tesla, Leaf, Volt, etc).
GS450h Transmission
The input shaft on the transmission has 21 splines, with a 28mm major diameter. It is believed that there are several Toyota clutches which will have this in their centre. The original GS450h flywheel and coupler also contains the appropriate slined centre, of course.
- It is recommended to purchase one which has the electric oil pump fitted - these are a costly item as the bearings in them often fail, in some cases they cost more than the transmission.
Wiring Harness Connectors
Connector | Part No. | Location | |
Inverter interface connector (A62) | 90980–12630 | Black connector on the side of the inverter. This connector is not sold anywhere to our knowledge. |
ECT Solenoid (E83) | Sumitomo 6189-1092 | Located on the left hand side of the transmission above the oil pan. | |
Shift Lever Position Sensor (E80) | Sumitomo 90980-12362 | Located on the right side of the transmission next to the shift lever inhibitor switch. | |
MG1 & MG2 Resolver(s) (E81 & E82) | Sumitomo 6189-1240 | Located on the left side of the transmission by the bell housing. |
Oil Pump Temperature Sensor | Sumitomo 6189-0175 | The connector is the small 2-pin connector in the middle of the harness between the oil pump and controller | |
HVECU -> Oil Pump Controller (A52) | Single large (7-way) connector on the side of the oil pump controller |
Control Board
An open-source VCU, designed by Damien Maguire, can be purchased as both partially populated and fully populated and tested boards on his website:
Lexus GS450H VCM Fully Built and Tested
- 33472-2002 (Left side, grey in colour)
- 33472-2001 (Right side, black in colour)
- 33012-2002 (Crimp terminals)
Development History
Vendors
There are currently no vendors who offer support on any aspects of the GS450h VCU.
Support
