Connector Part Numbers
This page contains part numbers for connectors on various openinverter boards
Prius Gen2 Inverter Controller
Part Type Part Name Part Number Remarks
Header 10-pole 90° Header 61201021721
Header Cinch 12+20 header 5810132011
Enclosure Cinch enclosure 5810130065
Connector Molex 20-pin 0334722002
Connector Molex 12-pin 0334721201
Pin Molex Pin 0330122002
Connector TE 32-pin (inside inverter) 1318747-1
Pin TE pins (inside inverter) 1123343-1
Chevy Volt Gen2 Charger P/N 24281923
LV Connector Molex MX150 33472-1201 https://openinverter.org/forum/viewtopic.php?t=1690#
HV DC connector TE HVA280 2103628 https://www.te.com/en/product-2103628-1.html
HV AC Connector Aptive HES 6 Way Connector Type 103 13879048 https://eu.mouser.com/ProductDetail/Aptiv-formerly-Delphi/13879048?qs=ZkWKQR8GT5%2FbuA9eSR%2FFiA%3D%3D
HV AC Connector pins Aptive HES Type 103 Pins 13783301-L https://eu.mouser.com/ProductDetail/Aptiv-formerly-Delphi/13783301-L?qs=42rJWdla%2FgotUv9ir%252B%2FFiA%3D%3D
Chevrolet Volt Gen2 DC-DC converter P/N 24281923
JST LV CONNECTOR ATSSPB-C0802Y-1AK 33472-1201 https://eu.mouser.com/ProductDetail/JST-Automotive/ATSSPB-C0802Y-1AK?qs=xwQlLnDx56Cob1elKfHzRw%3D%3D
HV CONNECTOR DELPHI / APTIV 33107347 https://eu.mouser.com/ProductDetail/Aptiv-formerly-Delphi/33107347?qs=apCURoLtCZHBY9y%252BDPZL3w%3D%3D
FOCCCI
Header Deutsch 12+12 header ATM13-12PA-12PB-BM03 https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/ATM13-12PA-12PB-BM03/9953955
Enclosure Enclosure EEC-325X4B https://www.digikey.de/de/products/detail/te-connectivity-deutsch-ict-connectors/EEC-325X4B/6566624
Connector Amphenol 12-pin grey ATM06-12SA https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/ATM06-12SA/5227558
Connector Amphenol 12-pin black ATM06-12SB https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/ATM06-12SB/5227559
Pin Pin matching Deutsch header AT62-201-20141 https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/AT62-201-20141/5227536
Wedge CONN PLUG WEDGE 12POS AWM-12S https://www.digikey.de/de/products/detail/amphenol-sine-systems-corp/AWM-12S/5227596
ELCON 1000W DCDC Converter
Schematic https://www.thunderstruck-ev.com/images/companies/1/DCDC/Elcon-TDC-IY_1KW_DC-DC.pdf?1684167663610
Connector HV Connector A128815-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/4-2103177-2/5423203
Pin 11-13 AWG (2) A128336CT-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-968853-3/5437364
Gasket Cable Seal, Size B A128082-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1587826-2/5423172
Ferrule Inner Ferrule (2) 1587828-2-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1587828-2/5423189
Ferrule Outer Ferrule (2) A142516-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1587829-2/9925419
Retainer Cable Seal Retainer A128448-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/2103181-2/5423169
Connector CANBus DJ7041-1.5-21 Generic 4-wire waterproof connector. Many sources including Amazon.
Current Sensor
Sensor DHAB S-137 (1000A) 398-DHABS/137-ND https://www.digikey.com/en/products/detail/lem-usa-inc/DHAB-S-137/22118080(must less expensive than getting from an EV store)
Sensor DHAB S-124 (500A) 398-DHABS/124-ND https://www.digikey.com/en/products/detail/lem-usa-inc/DHAB-S-124/22117976
Connector AMP 4-pin A127756-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-1456426-5/5437233
Pin 15-17 Awg (4) A142535TR-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1418850-1/2311440
