BMW Electronic Throttle Pedal
Revision as of 01:47, 8 January 2022 by Crasbe (talk | contribs) (Added even more part numbers.)
General Information
The pedal module has two independently working sensors (potentiometer or hall effect) for redundancy and plausibility checks. Sensor 2 outputs exactly half the voltage of Sensor 1.
In the original design the DME (Digital Motor Electronics) provides an independent, precision +5V sources for each of the two sensors. It should be noted here that the +5V supply voltage should be precise and stable to assure no erroneous readings from the Inverter Controller.
Pinout and Nominal Voltages
The Accelerator Pedal Module for manual and automatic gearbox do not differ in their pinout or electrical connector used. The nominal voltage values are the same for all pedal versions.
Nominal Voltage Range
Position Voltage Sensor 1 Voltage Sensor 2
Idle 0.70-0.80V 0.31-0.43V
Full Load 3.65-4.10V 1.83-2.04V
Resistance Point Kickdown 4.27-4.33V 2.14-2.16V
Mechanical Stop <4.76V <2.38V
Accelerator Pedal Version 1
BMW E46 Throttle Pedal Schematic
BMW E46 Throttle Pedal ETK [1]
Pinout and Cable Colors (from E46, may vary for other vehicles)
Pin Number Cable Color Function
1 Brown-Green Ground
2 Brown Ground
3 Yellow-Green +5V Supply
4 White Signal Sensor 1
5 Yellow +5V Supply
6 White-Green Signal Sensor 2
Part Numbers (derived from E46, might vary for other vehicles)
No Description Part Number Vehicles Used Status
01 Accelerator Pedal Module, Automatic Gearbox 35 40 1165703 Until 10/1999
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6753053 Until 08/2000
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6753518 Until 11/2001
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6756492 Until 05/2002
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6762480 Until 02/2006
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6772705 Until 05/2008
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6786281 E38, E39, E46, E53
01 Accelerator Pedal Module, Manual Gearbox 35 40 1165704 Until 10/1999
01 Accelerator Pedal Module, Manual Gearbox 35 40 6753094 Until 07/2001
01 Accelerator Pedal Module, Manual Gearbox 35 40 6753519 Until 03/2002
01 Accelerator Pedal Module, Manual Gearbox 35 40 6756493 Until 06/2002
01 Accelerator Pedal Module, Manual Gearbox 35 40 6762481 Until 02/2006
01 Accelerator Pedal Module, Manual Gearbox 35 42 6772706 Until 07/2008
01 Accelerator Pedal Module, Manual Gearbox 35 42 6786282 E38, E39, E46, E52, E53
02 Adapter Plate, Accelerator Pedal Module 35 42 6772703
02 Adapter Plate, Accelerator Pedal Module 35 42 6772704
03 Torx-bolt with washer, M8x20 07 12 9905423
04 Accelerator Pedal Bracket 35 41 1163875 Until 09/2003
04 Frame 32 30 3411677 From 2003/09
05 Self-locking hex nut, M6 07 14 7153450 From 07/2007
06 Blind plug, D=25mm 35 41 1163890
07 Socket Housing 6 Pin 61 13 8383300
-- Bushing contact 0.2-0.5mm² 61 13 0005197
Accelerator Pedal Version 2
BMW E60/E61 Throttle Pedal Schematic
BMW E60/E61 Throttle Pedal ETK [2]
Pinout and Cable Colors (from E60/E61, may vary for other vehicles)
2 Brown-Blue Ground
3 Yellow-Blue +5V Supply
4 White-Green Signal Sensor 1
5 Yellow-Green +5V Supply
6 White-Blue Signal Sensor 2
Part Numbers (derived from E60/E61, may vary for other vehicles)
01 Accelerator Pedal Module, Manual Gearbox 35 41 6754783 Until 11/2001
01 Accelerator Pedal Module, Manual Gearbox 35 41 6759724 Until 12/2005
01 Accelerator Pedal Module, Manual Gearbox 35 40 6766931 Until 02/2006
01 Accelerator Pedal Module, Manual Gearbox 35 41 6762327 Until 04/2008
01 Accelerator Pedal Module, Manual Gearbox 35 42 6772646 Until 07/2008
01 Accelerator Pedal Module, Manual Gearbox 35 42 6788633 Until 12/2009
01 Accelerator Pedal Module, Manual Gearbox 35 42 6786286 Until 08/2011
01 Accelerator Pedal Module, Manual Gearbox 35 42 6789999 Until 10/2012
01 Accelerator Pedal Module, Manual Gearbox 35 42 6852643 Until 06/2013
01 Accelerator Pedal Module, Manual Gearbox 35 42 6858575 E60, E61, E63, E64, E83, E85, E89, E90, E91, E92, E93,
F10, F11, F18, F25
Until 08/2014
01 Accelerator Pedal Module, Manual Gearbox 35 42 6860785 E60, E61, E63, E64, E83, E84, E85, E89, E90, E91, E92, E93,
F10, F11, F18, F25
Until 09/2015
01 Accelerator Pedal Module, Manual Gearbox 35 42 6860000 E60, E61, E63, E64, E83, E84, E85, E89, E90, E91, E92, E93,
F10, F11, F18, F25, F45, F46, F48
Until 07/2020
01 Accelerator Pedal Module, Manual Gearbox 35 40 6889823 E60, E61, E63, E64, E83, E84, E85, E89, E90, E91, E92, E93,
F10, F11, F25, F26, F39, F45, F46, F48,
G29
01 Accelerator Pedal Module, Automatic Gearbox 35 41 6752614 Until 11/2001
01 Accelerator Pedal Module, Automatic Gearbox 35 41 6759723 Until 09/2004
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6766930 Until 01/2006
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6772645 Until 08/2008
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6786285 Until 07/2011
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6762326 Until 08/2011
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6852644 Until 03/2012
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6858574 E60, E61, E63, E64, E65, E66, E67, E68, E70, E71, E72, E83, E85, E86, E89, E90, E91, E92, E93,
F01, F02, F03, F04, F06, F07, F10, F11, F12, F13, F18, F25
Until 06/2013
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6859999 E60, E61, E63, E64, E70, E71, E83, E84, E85, E89, E90, E91, E92, E93,
F06, F25, F45, F46, F48,
G11, G12
Until 07/2020
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6889822 E60, E61, E63, E64, E65, E70, E71, E72, E83, E84, E85, E89, E90, E91, E92, E93,
F01, F02, F04, F05, F06, F07, F10, F11, F12, F13, F25, F26, F39, F45, F46, F48,
G11, G12, G14, G15, G16, G28, G29, G30, G31, G32
02 Filister Head Screw M6x16 07 12 9905536
02 ISA Screw M6x16 07 12 9904588
03 Cover D=10mm 35 42 6796540
04 Cable Clamp A=3.5-6.0mm 07 14 7547239
05 Socket Housing 6 Pin 61 13 8383300
-- Pins for Socket Housing MQS ELA 0.75mm² 61 13 8366260
Accelerator Pedal Version 3
BMW E81/E82/E87/E88 Throttle Pedal Schematic
Part Numbers (derived from E87, might vary for other vehicles)
01 Accelerator Pedal Module, Manual Gearbox 35 42 6770935 Until 02/2008
01 Accelerator Pedal Module, Manual Gearbox 35 42 6786589 Until 07/2009
01 Accelerator Pedal Module, Manual Gearbox 35 42 6789529 Until 06/2013
01 Accelerator Pedal Module, Manual Gearbox 35 42 6793742 Until 06/2013
01 Accelerator Pedal Module, Manual Gearbox 35 42 6853176 Until 03/2020
01 Accelerator Pedal Module, Manual Gearbox 35 40 6889819
01 Accelerator Pedal Module, Manual Gearbox (Stainless Steel Pad) 35 42 6791474
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6786588 Until 11/2009
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6770936 Until 10/2011
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6789528 Until 06/2013
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6793743 Until 06/2013
01 Accelerator Pedal Module, Automatic Gearbox 35 42 6853175 Until 03/2020
01 Accelerator Pedal Module, Automatic Gearbox 35 40 6889818
02 Fillister head screw, M6x16 07 12 9905536
02 ISA screw, M6x16 07 12 9904588
03 Cover bolt D=10mm 35 42 6796540
ETK Link: https://www.bmw-etk.info/parts-catalog/prd/BMW/VT/P/E87/SH/116i/ECE/L/N/2003/04/48922/35/35_0274/07129904588
