MG Coolant Heater
Heater Operating Voltage 230–450V
Rated Heater Output 3.5kW
Part No. 10769109
Mechanical
Dimensions 18cm x 14cm x10cm
Fittings 19mm
Low Voltage Connections
!Note numbering is 1 is top left if the Keying wings are at the top.
CC is a 12V wake up in / ignition
KL31 is Ground
KL30 is permanent 12V
No CAN termination inside
High Voltage Connections
Red-PositiveBlue-Negative
TE Connector Component Side: 2-2310540-2 HVA280 Key B
CAN Bus
Heater sends out two CAN Ids
0x2B5
-No known content
0x2B6
-Byte 2 | HV voltage = Value x 2 +100
0x2A0 Control Id
Length of 8 byte
0x00 0x00 0x01 0x00 0x00 0x60 0x00 0x00 - This content causes current draw
