Zombieverter Parameters and Spot Values
Revision as of 17:34, 1 October 2024 by GregFordyce (talk | contribs)
Dual *note: this page is a work in progress.
I Name VCU Pin Unit Min Max Default Description
- General Setup
0 Inverter 0 8 0 None
Leaf_Gen1
GS450H
User Can
Open1
Prius_Gen3
Outlander
GS300H
RearOutlander
1 Vehicle 0 8 0 BMW_E46
BMW_E65
Classic
None
BMW_E39
VAG
Subaru
BMW_E31
2 Transmission 0 1 0
3 interface 0 3 0
4 chargemodes 0 6 0
5 InverterCan 0 1 0
6 VehicleCan 0 1 1
7 ShuntCan 0 1 0
8 LimCan 0 1 0
9 ChargerCan 0 1 1
10 BMSCan 0 1 1
11 OBD2Can 0 1 0
12 CanMapCan 0 1 0
13 DCDCCan 0 1 1
14 GearLvr 0 3 0
15 MotActive 0 2 0
- Throttle
16 potmin dig 0 4095 0 Value of "pot" when pot isn't pressed at all
17 potmax dig 0 4095 4095 Value of "pot" when pot is pushed all the way in
18 pot2min dig 0 4095 4095 Value of "pot2" when regen pot is in 0 position
19 pot2max dig 0 4095 4095 Value of "pot2" when regen pot is in full on position
20 regenrpm rpm 100 10000 1500
21 regenendrpm rpm 100 10000 100
22 regenmax % -30 0 -10
23 regenBrake % -30 0 -10
24 regenramp %/10ms 0.09 100 100 Ramp speed when entering regen. E.g. when you set brkmax to -30% and regenramp to 1, it will take 300ms to arrive at brake force of -60%
25 potmode 0 1 0 0=Single Channel
1=Dual Channel - Preferred setting
26 dirmode 0 4 1
27 reversemotor 0 1 0
28 throtramp %/10ms 0.09 100 100
29 throtramprpm rpm 0 20000 20000
30 revlim rpm 0 20000 6000
31 bmslimhigh % 0 100 50
32 bmslimlow % -100 0 -1
33 udcmin V 0 1000 450
34 udclim V 0 1000 520
35 idcmax A 0 5000 5000
36 idcmin A -5000 0 -5000
37 tmphsmax °C 50 150 85
38 tmpmmax °C 70 300 300
39 throtmax % 0 100 100
40 throtmin % -100 0 -100
41 throtmaxRev % 0 100 30
42 throtdead % 0 50 10
43 RegenBrakeLight % -100 0 -15
44 throtrpmfilt rpm/10ms 0.09 200 15
- Gearbox Control
45 Gear 0 2 0
46 OilPump % 0 100 50
- Cruise Control
47 cruisestep rpm 1 1000 200
48 cruiseramp rpm/100ms 1 1000 20
49 regenlevel 0 3 2
- Contactor Control
50 udcsw V 0 1000 330
51 cruiselight 0 1 0
52 errlights 0 255 0
- Communication
53 CAN3Speed 25 L
26 H
0 2 0
- Charger Control
54 BattCap kWh 0.09 250 22
55 Voltspnt V 0 1000 395
56 Pwrspnt W 0 12000 1500
57 IdcTerm A 0 150 0
58 CCS_ICmd A 0 150 0
59 CCS_ILim A 0 350 100
60 CCS_SOCLim % 0 100 80
61 SOCFC % 0 100 50
62 Chgctrl 0 2 0
63 ChgAcVolt Vac 0 250 240
64 ChgEff % 0 100 90
- DC-DC Converter
65 DCdc_Type 0 1 0
66 DCSetPnt V 9 15 14
- Battery Management
67 BMS_Mode 0 3 0
68 BMS_Timeout sec 1 120 10
69 BMS_VminLimit V 0 10 3
70 BMS_VmaxLimit V 0 10 4.18
71 BMS_TminLimit °C -100 100 5
72 BMS_TmaxLimit °C -100 100 50
- Heater Module
73 Heater 0 2 0
74 Control 0 2 0
75 HeatPwr W 0 6500 0
76 HeatPercnt % 0 100 0
- RTC Module
77 Set_Day 0 6 0
78 Set_Hour Hours 0 23 0
79 Set_Min Mins 0 59 0
80 Set_Sec Secs 0 59 0
81 Chg_Hrs Hours 0 23 0
82 Chg_Min Mins 0 59 0
83 Chg_Dur Mins 0 600 0
84 Pre_Hrs Hours 0 59 0
85 Pre_Min Mins 0 59 0
86 Pre_Dur Mins 0 60 0
- General Purpose I/O
87 Out1Func 0 13 6
88 Out2Func 4 0 13 7
89 Out3Func 3 0 13 3
90 SL1Func 39 0 13 0
91 SL2Func 38 0 13 0
92 PWM1Func 7 0 14 0
93 PWM2Func 6 0 14 4
94 PWM3Func 5 0 15 2
95 GP12VInFunc 50 0 13 12
96 HVReqFunc 51 0 13 11
97 GPA1Func 36 0 2 0 Pot 1 *verification required
98 GPA2Func 35 0 2 0 Pot 2 *verification required
99 ppthresh dig 0 4095 2500
100 BrkVacThresh dig 0 4095 2500
101 BrkVacHyst dig 0 4095 2500
- ISA Shunt Control
102 IsaInit 0 1 0
103 Type 0 2 0
- PWM Control
104 Tim3_Presc 1 72000 719
105 Tim3_Period 1 100000 7200
106 Tim3_1_OC 1 100000 3600
107 Tim3_2_OC 1 100000 3600
108 Tim3_3_OC 1 100000 3600
Spot Values
Name Description Value Unit CAN Id Position Bits Gain Map to CAN Notes Additional Notes
version 2.17.A TX�RX
opmode Off TX�RX
chgtyp Off TX�RX
lasterr NONE TX�RX
status PotPressed TX�RX
udc 0 V TX�RX
udc2 0 V TX�RX
udc3 0 V TX�RX
deltaV 0 V TX�RX
INVudc 0 V TX�RX
power 0 kW TX�RX
idc 0 A TX�RX
KWh 0 kwh TX�RX
AMPh 0 Ah TX�RX
SOC 100 % TX�RX
BMS_Vmin 0 V TX�RX
BMS_Vmax 0 V TX�RX
BMS_Tmin 0 °C TX�RX
BMS_Tmax 0 °C TX�RX
BMS_ChargeLim 9999 A TX�RX
speed 0 rpm TX�RX
Veh_Speed 0 kph TX�RX
torque 0 dig TX�RX
pot 12 dig TX�RX
pot2 5 dig TX�RX
potbrake 0 dig TX�RX
brakepressure 0 dig TX�RX
potnom 0 % TX�RX
dir Neutral TX�RX
tmphs 0 °C TX�RX
tmpm 0 °C TX�RX
tmpaux 0 °C TX�RX
uaux 14.68 V TX�RX
canio TX�RX
FrontRearBal 50 % TX�RX
cruisespeed 0 rpm TX�RX
cruisestt None TX�RX
din_cruise Off TX�RX
din_start Off TX�RX
din_brake Off TX�RX
din_forward Off TX�RX
din_reverse Off TX�RX
din_bms Off TX�RX
din_12Vgp Off TX�RX
handbrk Off TX�RX
Gear1 Off TX�RX
Gear2 Off TX�RX
Gear3 Off TX�RX
T15Stat Off TX�RX
InvStat Off TX�RX
GearFB LOW TX�RX
CableLim 0 A TX�RX
PilotLim 0 A TX�RX
PlugDet Off TX�RX
PilotTyp Absent TX�RX
CCS_I_Avail 0 A TX�RX
CCS_V_Avail 0 V TX�RX
CCS_I 0 A TX�RX
CCS_Ireq 0 A TX�RX
CCS_V 0 V TX�RX
CCS_V_Min 0 V TX�RX
CCS_V_Con 0 V TX�RX
hvChg Off TX�RX
CCS_COND NotRdy TX�RX
CCS_State 0 s TX�RX
CP_DOOR CLOSED TX�RX
CCS_Contactor Off TX�RX
Day Sun TX�RX
Hour 0 H TX�RX
Min 3 M TX�RX
Sec 25 S TX�RX
ChgT 0 M TX�RX
HeatReq Off TX�RX
U12V 0 V TX�RX
I12V 0 A TX�RX
ChgTemp 0 °C TX�RX
AC_Volts 0 V TX�RX
AC_Amps 0 A TX�RX
canctr 0 dig TX�RX
cpuload 0.78 % TX�RX
PPVal 0 dig TX�RX
BrkVacVal 0 dig TX�RX
tmpheater 0 °C TX�RX
udcheater 0 V TX�RX
powerheater 0 W TX�RX
serial 43212553 TX�RX
