Zombieverter Parameters and Spot Values
Jump to navigation
Jump to search
I | Name | VCU Pin | Unit | Min | Max | Default | Description |
- General Setup | |||||||
0 | Inverter | 0 | 8 | 0 | None
Leaf_Gen1 GS450H User Can Open1 Prius_Gen3 Outlander GS300H RearOutlander | ||
1 | Vehicle | 0 | 8 | 0 | BMW_E46
BMW_E65 Classic None BMW_E39 VAG Subaru BMW_E31 | ||
2 | Transmission | 0 | 1 | 0 | Manual
Auto | ||
3 | interface | 0 | 3 | 0 | unused
i3LIM Chademo CPC | ||
4 | chargemodes | 0 | 6 | 0 | Off
EXT_DIGI Volt_Ampera TeslaOI Out_lander Elcon | ||
5 | InverterCan | 0 | 1 | 0 | |||
6 | VehicleCan | 0 | 1 | 1 | |||
7 | ShuntCan | 0 | 1 | 0 | |||
8 | LimCan | 0 | 1 | 0 | |||
9 | ChargerCan | 0 | 1 | 1 | |||
10 | BMSCan | 0 | 1 | 1 | |||
11 | OBD2Can | 0 | 1 | 0 | |||
12 | CanMapCan | 0 | 1 | 0 | |||
13 | DCDCCan | 0 | 1 | 1 | |||
14 | GearLvr | 0 | 3 | 0 | None
BMW_F30 JLR_G1 JLR_G2 | ||
15 | MotActive | 0 | 2 | 0 | Mg1and2
Mg1 Mg2 | ||
- Throttle | |||||||
16 | potmin | dig | 0 | 4095 | 0 | Value of "pot" when pot isn't pressed at all | |
17 | potmax | dig | 0 | 4095 | 4095 | Value of "pot" when pot is pushed all the way in | |
18 | pot2min | dig | 0 | 4095 | 4095 | Value of "pot2" when regen pot is in 0 position | |
19 | pot2max | dig | 0 | 4095 | 4095 | Value of "pot2" when regen pot is in full on position | |
20 | regenrpm | rpm | 100 | 10000 | 1500 | ||
21 | regenendrpm | rpm | 100 | 10000 | 100 | ||
22 | regenmax | % | -30 | 0 | -10 | ||
23 | regenBrake | % | -30 | 0 | -10 | ||
24 | regenramp | %/10ms | 0.09 | 100 | 100 | Ramp speed when entering regen. E.g. when you set brkmax to -30% and regenramp to 1, it will take 300ms to arrive at brake force of -60% | |
25 | potmode | 31 GND
32 Thr2 33 Thr1 34 +5v |
0 | 1 | 0 | 0=Single Channel
1=Dual Channel - Preferred setting | |
26 | dirmode | 53 Rev
54 Fwd |
0 | 4 | 1 | Button
Switch ButtonReversed SwitchReversed DefaultForward | |
27 | reversemotor | 0 | 1 | 0 | Off
On na | ||
28 | throtramp | %/10ms | 0.09 | 100 | 100 | ||
29 | throtramprpm | rpm | 0 | 20000 | 20000 | ||
30 | revlim | rpm | 0 | 20000 | 6000 | ||
31 | bmslimhigh | % | 0 | 100 | 50 | ||
32 | bmslimlow | % | -100 | 0 | -1 | ||
33 | udcmin | V | 0 | 1000 | 450 | ||
34 | udclim | V | 0 | 1000 | 520 | ||
35 | idcmax | A | 0 | 5000 | 5000 | ||
36 | idcmin | A | -5000 | 0 | -5000 | ||
37 | tmphsmax | °C | 50 | 150 | 85 | ||
38 | tmpmmax | °C | 70 | 300 | 300 | ||
39 | throtmax | % | 0 | 100 | 100 | ||
40 | throtmin | % | -100 | 0 | -100 | ||
41 | throtmaxRev | % | 0 | 100 | 30 | ||
42 | throtdead | % | 0 | 50 | 10 | ||
43 | RegenBrakeLight | % | -100 | 0 | -15 | ||
44 | throtrpmfilt | rpm/10ms | 0.09 | 200 | 15 | ||
- Gearbox Control | |||||||
45 | Gear | 0 | 2 | 0 | Low
High Auto | ||
46 | OilPump | % | 0 | 100 | 50 | ||
- Cruise Control | |||||||
47 | cruisestep | rpm | 1 | 1000 | 200 | ||
48 | cruiseramp | rpm/100ms | 1 | 1000 | 20 | ||
49 | regenlevel | 0 | 3 | 2 | |||
- Contactor Control | |||||||
50 | udcsw | V | 0 | 1000 | 330 | ||
51 | cruiselight | 0 | 1 | 0 | Off
On na | ||
52 | errlights | 0 | 255 | 0 | Off
EPC engine | ||
- Communication | |||||||
53 | CAN3Speed | 25 L
26 H |
0 | 2 | 0 | k33.3
k500 k100 | |
- Charger Control | |||||||
54 | BattCap | kWh | 0.09 | 250 | 22 | ||
55 | Voltspnt | V | 0 | 1000 | 395 | ||
56 | Pwrspnt | W | 0 | 12000 | 1500 | ||
57 | IdcTerm | A | 0 | 150 | 0 | ||
58 | CCS_ICmd | A | 0 | 150 | 0 | ||
59 | CCS_ILim | A | 0 | 350 | 100 | ||
60 | CCS_SOCLim | % | 0 | 100 | 80 | ||
61 | SOCFC | % | 0 | 100 | 50 | ||
62 | Chgctrl | 0 | 2 | 0 | Enable
Disable Timer | ||
63 | ChgAcVolt | Vac | 0 | 250 | 240 | ||
64 | ChgEff | % | 0 | 100 | 90 | ||
- DC-DC Converter | |||||||
65 | DCdc_Type | 0 | 1 | 0 | No DCDC
TeslaG2 | ||
66 | DCSetPnt | V | 9 | 15 | 14 | ||
- Battery Management | |||||||
67 | BMS_Mode | 0 | 3 | 0 | Off
SimpBMS TiDaisychainSingle TiDaisychainDual | ||
68 | BMS_Timeout | sec | 1 | 120 | 10 | ||
69 | BMS_VminLimit | V | 0 | 10 | 3 | ||
70 | BMS_VmaxLimit | V | 0 | 10 | 4.18 | ||
71 | BMS_TminLimit | °C | -100 | 100 | 5 | ||
72 | BMS_TmaxLimit | °C | -100 | 100 | 50 | ||
- Heater Module | |||||||
73 | Heater | 0 | 2 | 0 | None
Ampera VW | ||
74 | Control | 0 | 2 | 0 | Disable
Enable Timer | ||
75 | HeatPwr | W | 0 | 6500 | 0 | ||
76 | HeatPercnt | % | 0 | 100 | 0 | ||
- RTC Module | |||||||
77 | Set_Day | 0 | 6 | 0 | |||
78 | Set_Hour | Hours | 0 | 23 | 0 | ||
79 | Set_Min | Mins | 0 | 59 | 0 | ||
80 | Set_Sec | Secs | 0 | 59 | 0 | ||
81 | Chg_Hrs | Hours | 0 | 23 | 0 | ||
82 | Chg_Min | Mins | 0 | 59 | 0 | ||
83 | Chg_Dur | Mins | 0 | 600 | 0 | ||
84 | Pre_Hrs | Hours | 0 | 59 | 0 | ||
85 | Pre_Min | Mins | 0 | 59 | 0 | ||
86 | Pre_Dur | Mins | 0 | 60 | 0 | ||
- General Purpose I/O | |||||||
87 | Out1Func | 0 | 13 | 6 | |||
88 | Out2Func | 4 | 0 | 13 | 7 | ||
89 | Out3Func | 3 | 0 | 13 | 3 | ||
90 | SL1Func | 39 | 0 | 13 | 0 | ||
91 | SL2Func | 38 | 0 | 13 | 0 | ||
92 | PWM1Func | 7 | 0 | 14 | 0 | ||
93 | PWM2Func | 6 | 0 | 14 | 4 | ||
94 | PWM3Func | 5 | 0 | 15 | 2 | ||
95 | GP12VInFunc | 50 | 0 | 13 | 12 | ||
96 | HVReqFunc | 51 | 0 | 13 | 11 | ||
97 | GPA1Func | 36 | 0 | 2 | 0 | Pot 1 *verification required | |
98 | GPA2Func | 35 | 0 | 2 | 0 | Pot 2 *verification required | |
99 | ppthresh | dig | 0 | 4095 | 2500 | ||
100 | BrkVacThresh | dig | 0 | 4095 | 2500 | ||
101 | BrkVacHyst | dig | 0 | 4095 | 2500 | ||
- ISA Shunt Control | |||||||
102 | IsaInit | 0 | 1 | 0 | |||
103 | Type | 0 | 2 | 0 | |||
- PWM Control | |||||||
104 | Tim3_Presc | 1 | 72000 | 719 | |||
105 | Tim3_Period | 1 | 100000 | 7200 | |||
106 | Tim3_1_OC | 1 | 100000 | 3600 | |||
107 | Tim3_2_OC | 1 | 100000 | 3600 | |||
108 | Tim3_3_OC | 1 | 100000 | 3600 |
Spot Values
Name | Description | Value | Unit | CAN Id | Position | Bits | Gain | Map to CAN | Notes | Additional Notes |
version | 2.17.A | TX�RX | ||||||||
opmode | Off | TX�RX | ||||||||
chgtyp | Off | TX�RX | ||||||||
lasterr | NONE | TX�RX | ||||||||
status | PotPressed | TX�RX | ||||||||
udc | 0 | V | TX�RX | |||||||
udc2 | 0 | V | TX�RX | |||||||
udc3 | 0 | V | TX�RX | |||||||
deltaV | 0 | V | TX�RX | |||||||
INVudc | 0 | V | TX�RX | |||||||
power | 0 | kW | TX�RX | |||||||
idc | 0 | A | TX�RX | |||||||
KWh | 0 | kwh | TX�RX | |||||||
AMPh | 0 | Ah | TX�RX | |||||||
SOC | 100 | % | TX�RX | |||||||
BMS_Vmin | 0 | V | TX�RX | |||||||
BMS_Vmax | 0 | V | TX�RX | |||||||
BMS_Tmin | 0 | °C | TX�RX | |||||||
BMS_Tmax | 0 | °C | TX�RX | |||||||
BMS_ChargeLim | 9999 | A | TX�RX | |||||||
speed | 0 | rpm | TX�RX | |||||||
Veh_Speed | 0 | kph | TX�RX | |||||||
torque | 0 | dig | TX�RX | |||||||
pot | 12 | dig | TX�RX | |||||||
pot2 | 5 | dig | TX�RX | |||||||
potbrake | 0 | dig | TX�RX | |||||||
brakepressure | 0 | dig | TX�RX | |||||||
potnom | 0 | % | TX�RX | |||||||
dir | Neutral | TX�RX | ||||||||
tmphs | 0 | °C | TX�RX | |||||||
tmpm | 0 | °C | TX�RX | |||||||
tmpaux | 0 | °C | TX�RX | |||||||
uaux | 14.68 | V | TX�RX | |||||||
canio | TX�RX | |||||||||
FrontRearBal | 50 | % | TX�RX | |||||||
cruisespeed | 0 | rpm | TX�RX | |||||||
cruisestt | None | TX�RX | ||||||||
din_cruise | Off | TX�RX | ||||||||
din_start | Off | TX�RX | ||||||||
din_brake | Off | TX�RX | ||||||||
din_forward | Off | TX�RX | ||||||||
din_reverse | Off | TX�RX | ||||||||
din_bms | Off | TX�RX | ||||||||
din_12Vgp | Off | TX�RX | ||||||||
handbrk | Off | TX�RX | ||||||||
Gear1 | Off | TX�RX | ||||||||
Gear2 | Off | TX�RX | ||||||||
Gear3 | Off | TX�RX | ||||||||
T15Stat | Off | TX�RX | ||||||||
InvStat | Off | TX�RX | ||||||||
GearFB | LOW | TX�RX | ||||||||
CableLim | 0 | A | TX�RX | |||||||
PilotLim | 0 | A | TX�RX | |||||||
PlugDet | Off | TX�RX | ||||||||
PilotTyp | Absent | TX�RX | ||||||||
CCS_I_Avail | 0 | A | TX�RX | |||||||
CCS_V_Avail | 0 | V | TX�RX | |||||||
CCS_I | 0 | A | TX�RX | |||||||
CCS_Ireq | 0 | A | TX�RX | |||||||
CCS_V | 0 | V | TX�RX | |||||||
CCS_V_Min | 0 | V | TX�RX | |||||||
CCS_V_Con | 0 | V | TX�RX | |||||||
hvChg | Off | TX�RX | ||||||||
CCS_COND | NotRdy | TX�RX | ||||||||
CCS_State | 0 | s | TX�RX | |||||||
CP_DOOR | CLOSED | TX�RX | ||||||||
CCS_Contactor | Off | TX�RX | ||||||||
Day | Sun | TX�RX | ||||||||
Hour | 0 | H | TX�RX | |||||||
Min | 3 | M | TX�RX | |||||||
Sec | 25 | S | TX�RX | |||||||
ChgT | 0 | M | TX�RX | |||||||
HeatReq | Off | TX�RX | ||||||||
U12V | 0 | V | TX�RX | |||||||
I12V | 0 | A | TX�RX | |||||||
ChgTemp | 0 | °C | TX�RX | |||||||
AC_Volts | 0 | V | TX�RX | |||||||
AC_Amps | 0 | A | TX�RX | |||||||
canctr | 0 | dig | TX�RX | |||||||
cpuload | 0.78 | % | TX�RX | |||||||
PPVal | 0 | dig | TX�RX | |||||||
BrkVacVal | 0 | dig | TX�RX | |||||||
tmpheater | 0 | °C | TX�RX | |||||||
udcheater | 0 | V | TX�RX | |||||||
powerheater | 0 | W | TX�RX | |||||||
serial | 43212553 | TX�RX |
