Tesla Model S GEN1 Charger
Revision as of 15:03, 5 October 2024 by Asavage (talk | contribs) (→‎Overview: Added info about their use in early Supercharger stations.)
Tesla GEN1 Onboard AC Charger
Tesla GEN1 Onboard AC Charger. Note the stamped "TESLA" on the cover, which visually distinguishes it from later versions. This view shows the Logic Connector X042/X043
A version of this unit was used in early Tesla Supercharger DCFC stations, with several ganged in parallel.
Charger Connectors
Tesla Model S GEN1 OBC Connectors
  • Logic (X042 (or X043, when used in "Slave" mode))
  • AC (Input)
  • DC (Output)
  • Fast Charge (DCFC) Contactors Control (2x)
  • Tesla: In Single OBC vehicles, all connectors are used. This is the most common scenario.
  • Tesla: In Dual OBC vehicles, the second ("Slave") OBC does not utilize the following, as the first ("Master") OBC performs those functions:
    • the Fast Charge Contactors connectors
    • the HVIL Loop connector
  • Toyota: The Fast Charge Contactors connectors are not used, as the vehicle is not provisioned for DCFC and therefore there are no Fast Charge Contactors.
Tesla Model S GEN1 OBC Logic Connector X042 Wiring. Tesla wiring diagrams do not define all circuits for a connector. This diagram has been amended to include circuits from other pages, to completely describe X042.
Tesla Model S GEN1 OBC Logic Connector X042 Wiring, from Service Manual sheet 16.1.  Tesla wiring diagrams do not define all circuits for a connector; this diagram has been amended to include circuits from other sheets 24.2 (HVIL) & 38.1 (CAN), to completely describe X042.
Tesla Model S GEN1 OBC X042 Logic Connector pinout.
Telsa Model S (2012-2013) OBC Logic Connector X042 details, from Tesla Service Manual.
Logic Connector X042 (Master charger) and X043 (Slave charger). Molex 19418-0026, female harness connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
Logic Connector X042, Master charger, and X043, Slave charger. Molex 19418-0026, female connector to mate with X042 Logic Connector on Tesla GEN1 OBC.
Molex 19418-0026, female harness-side connector to mate with X042 (male terminals) Logic Connector on Tesla GEN1 OBC (Logic Connector X042 (Master charger) and X043 (Slave charger)). This is the terminals-end view of the housing.
Wire size *
Telsa
Wire Color *
2 ** Charge Port: nozzle lock "InsertEN out" 20 AWG (0.5mm²) YL
4 CAN + 20 AWG (0.5mm²) RD
6 ** Fast Charge CAN "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" 20 AWG (0.5mm²) RD-WH
7 12v GND 20 AWG (0.5mm²) BK
8 EVSE-Prox (PP) OUT PP signal from EVSE to Drive Unit. Marked "Prox out" on Tesla's documentation, this was thought to be a "inhibit drive" signal, but testing has been inconclusive/negative for that function so far. 22 AWG (0.35mm²) OR-PU
10 CAN - 20 AWG (0.5mm²) DB
11 EVSE-Prox (PP) IN PP signal from EVSE to OBC 20 AWG (0.5mm²) OR
12 ** "BMS_12V_in" "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables DCFC contactors?) 18 AWG (0.75mm²) RD-GY
** = Not used on RAV4 EV.
Tesla GEN1 OBC: "Slave" configuration Logic and HVIL connections.
Tesla Model S OBC in Single/Master configuration. Note "parked" harness WWMA2 on Rear HVJB.
AC Input Connector
DC Output Connector
Molex 8 AWG open barrel terminal, modified by removing the rear insulation crimp section, then crimped using Pressmaster MCT and die 4300-3146, using the 10 AWG position.
HVIL Connector (J5)
Tesla Model S GEN1 OBC: HVIL and HVJB AC Charging Bypass Contactor Control Connectors
Tesla Model S GEN1 OBC: HVIL and HVJB Fast Charge Contactor Control Connectors
  • Tesla: Connected to the HVJB's Lid Reed Switch if the OBC is the only (single) or Master (dual) OBC. If the OBC is configured as Second/Slave, a loopback harness is connected instead.
  • Tesla: The loopback harness, Tesla 1101371-00-A, is included/stored inside all Tesla Model S GEN1 Rear HVJB in an internal "parking" socket, when only a single OBC is provisioned.
  • Toyota: A loopback harness is always connected.
  • MB: TBD (probably a loopback harness is connected).
Tesla Model S GEN1 OBC HVIL Loopback connector. Used on Tesla Slave OBC installations where the HVJB Lid Reed Switch is already connected to the HVIL circuit via the Master OBC. Also used in RAV4 EV, as there is no HVJB installed at all in those models.
  • The top row pins are 12v; the bottom row pins are Auxiliary contacts, NO (normally open).
  • These connectors are not used in the Toyota RAV4 EV (and possibly not used in MB B250e) as the RAV4 EV is not provisioned for DCFC and does not have those contactors.
Common Issues
Grounding
Fuses
Eaton Bussmann FWH-50B semiconductor fuses are fast-blow to protect sensitive components. This fuse is reported to be a replacement for OEM Ferraz Shawmut A50P50-4
Semiconductor fuses may have a diode symbol imprinted, but this does not imply that the fuse functions as a diode.
Eaton Bussmann (Cooper) FWH-50B, showing the diode electrical symbol which indicates that it's a semiconductor fuse (very fast acting).
Important Considerations
Output Voltage Range
Tesla GEN1 OBC label, showing part No. and input/output specs. These are not to be relied upon.
HEED DAMIEN'S WARNING:[21]
(regarding the GEN2 OBC, which may or may not apply to the GEN1)
"Running a Tesla charger at much under 200v DC will cause it to explode. Yes I know the label says 50 to 450v but it lies. Yes I blew one up discovering this."
CAN
WIP
  • Dimensions: 19-13/16" L x 13-7/16" W x 4-7/16" H (503mm L x 341mm W x 113mm H)
  • Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
  • 6009278-00-x
  • 6009354-00-x
Toyota Part Numbers:
  • G9090-0R010 (discontinued)
  • G9090-0R011
MB Part Number(s):
  • TBD
