Nissan Leaf ZE1 AC compressor
Revision as of 16:42, 11 December 2024 by Tom91 (talk | contribs) (Created page with "thumb From Leaf model year 2017-2023 It is label Denso S1 ESB27C '''Low voltage Connector''' The pinout is as follows: Left most pin 12V ign, middle is ground, right is LIN thumb '''High Voltage Connector''' HV, Red is positive Blue is negative thumb...")
File:Https://openinverter.org/forum/download/file.php?id=33940&t=1
Low voltage Connector The pinout is as follows: Left most pin 12V ign, middle is ground, right is LIN
File:Https://openinverter.org/forum/download/file.php?id=33941&mode=view
File:Https://openinverter.org/forum/download/file.php?id=33942&t=1
LIN Bus Info Lin Speed 19200kbps Message rate 100Hz (0.1 S between same ID) Checksum: Enhanced
Compressor info ID 0x09 !!!Content unkown Control ID 0x07
OFF: 0x00,0x00,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF
Run: 0x00,0x05,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF
First two bytes control speed ? !!!to be verified
https://openinverter.org/forum/viewtopic.php?t=5723
