Volkswagen Heater
General Information [1]
  • Operating Voltage: 280VDC - 450VDC
  • Power: 5kW (7kW "boost" between 350-450V)
  • Control via LIN by integrated electronics
  • Temperature control by integrated sensor
  • 3d Scan: https://grabcad.com/
  • Fluid connection (mm): 20 (Nozzle dimensions according to DIN3021-3[2])
  • Dimensions L x W x H (mm): 210 x 73 x175
  • Weight (kg): ~1,7
Pinout/Connectors
HV connector: TE 4-2103177-5 (HVA 280 series - key "E")
  • HV+ near to the body,
  • HV- far from the body
LV connector: TE 1-1394416-1
  • Pin 1 is permanent 12V
  • Pin 2 is GND
  • Pin 4 is LIN
  • Pin 5 is HV Interlock loop passthrough (ref. right terminal highlighted with Blue in picture)
  • Pin 7 is HV interlock loop passthrough (ref. left terminal highlighted with Blue in picture)
LIN Bus Communication
Control and Answer Messages from/to Heater[3]
ID Description Length Checksum Type Byte 0 Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7
Dec: 28
Hex: 0x1C
PID: 0x9C
Control, every 50ms 2 Enhanced Power
0-100%
scale: x1
Last bit: Start/Stop
Dec: 48
Hex: 0x30
PID: 0xF0
Feedback 8 Enhanced HV Current:
Unit: Amp Scale: 0.25
?? ?? ?? LV Voltage:
Unit: Volt Scale: 0.1
Module Temp
Unit: Celcius offset:-50
Temperature in
Unit: Celsius offset:-50
Temperature out
VW Part Numbers
Heater:
  • 3Q0 963 231 A
  • 3Q0 963 231 C
  • 3Q0 963 231 E
Cable assemblies:
  • HV cable is 3Q0 971 475 or 5Q0 971 475
  • LV cable appears to be 1J0 973 714
