Honda Accelerator pedal sensor
General Information
The original cable is shielded to avoid interference from other sources and resulting unwanted acceleration or deceleration.
The voltage from both sensors ramps linearly from the fully released position to the fully depressed position[2]. The pedal should be supplied with a reasonable stable and accurate 5V supply to ensure a proper readout.
| Pedal Position | Sensor 1 | Sensor 2 |
| Fully Released | 0.05 V | 4.30 V |
| Fully Depressed | 0.10 V | 4.90 V |
Versions
| Part Number | Cars Used In | Electrical Connector | Remarks |
Connector can be found on Aliexpress |
Photos
3D scan of bracket, sensor, and cover
- ↑ Forum Reference: https://openinverter.org/forum/viewtopic.php?p=66006#p66006
- ↑ Add reference
