Mitsubishi Outlander Rear Inverter
| Property | Value | Source |
| Device | Combined Motor, Gearbox and Rear Differential | |
| OEM | Mitsubishi | |
| Type | AC Motor 10 Pole 3 Phase synchronous perm magnet brushless | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html
https://openinverter.org/forum/viewtopic.php?f=19&t=325&start=30 |
| Suppliers | Ebay, Second Life EV Batteries | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html |
| Max RPM | 9600RPM | |
| Mechanical Mounting | 6x M10 Bolt front face flange (all in same plane)
3x M? Bolt Rear Flange (all in same plane) used for bush mount on Outlander |
Author experience |
| Shaft Type | 20.02mm 18 splines, ~60mm long | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html |
| Resolver | SIN COS - P/N C69600/TS2239N484E102
| Weight | 42kg | https://www.secondlife-evbatteries.com/meiden-ev-motor-60kw-9300rpm.html |
| Power To Weight Ratio | 70kW Motor: 1.66 kW/kg | |
| Diff Ratio | 7.065:1 | http://www.mitsubishi-motors.com.hk/uploads/file_1465376705.pdf |
