Mitsubishi Outlander PHEV
The Mitsubishi Outlander PHEV (2012-2018 models) feature a compact CANBus controlled 3.7kw charger suitable for budget EV conversions. Units can be bought for under £200.
* Length 370mm * Width 270mm * Height 150mm
DC-DC Converter
The charger has an integrated DC-DC converter outputting a fixed 14.5V. The converter requires battery voltage between 200V and 420V on the DC bus.
To start the DC-DC converter, first to apply 12V to pin 7 and GND to pin 10. You also need to have its casing connected to common GND.
Pinout as as follows:
- Pin 1 (Orange) NC on outlander
- Pin 2 NC on outlander
- Pin 3 (Blue) NC on outlander
- Pin 4 DC SW (enables the DC:DC converter)
- Pin 5 CHIN (Serial protocol to EV Remote wifi module)
- Pin 6 CAN H (Black)
- Pin 7 Sense line for DC to DC converter
- Pin 8 IGCT main power to charger
- Pin 9 Proximity signal from charger
- Pin 10 GND
- Pin 11 NC
- Pin 12 CHOT (Serial protocol to EV Remote wifi module)
- Pin 13 CAN L (Red)
Charge Control
CANBus Messages
0x286 byte 2 sets the charge current, there is a voltage setting on byte 0 and 1 but that is completely ignored
- Byte 0-1 = Voltage setpoint - Byte 2 = Current in amps x 10
- B0+B1 = 12V Battery voltage (h04DC=12,45V -> 0,01V/bit) - B2+B3 = 12V Supply current (H53=8,3A -> 0,1A/bit) - B4 = Temperature 1 (starts at -40degC, +1degC/bit) - B5 = Temperature 2 (starts at -40degC, +1degC/bit) - B6 = Temperature 3 (starts at -40degC, +1degC/bit) - B7 = Statusbyte (h20=standby, h21=error, h22=in operation) - - bit0(LSB) = Error - - bit1 = In Operation - - bit3 = - - bit4 = - - bit5 = Ready - - bit6 = - - bit7(MSB) =
0x389
- B0 = Battery Voltage (as seen by the charger), needs to be scaled x 2, so can represent up to 255*2V; used to monitor battery during charge - B1 = Charger supply voltage, no scaling needed - B5-6 = Charger Supply Current x 100
0x38A
