VW Hybrid Battery Packs
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
BMS
Battery Modules
Passat GTE
Module Weight
BMS Board
Cooling
Original Pipework Connector
Contactors/Pre-Charge
Passat GTE
The Control box contains
  • PEC 300A 450VDC fuse
  • 1 x Contactor Control Board
Contactor Box
HV Contactor
Pre Charge Relay
INSERT
Resistor Pic
Fuse
Error creating thumbnail: File with dimensions greater than 12.5 MP
Shunt
Control Board
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
Using Multiple Packs
