VW Hybrid Battery Packs
Specification Overview
Passat GTE
Note: battery capacity has been increased to 13kwr in circa 2019 (assumed to be 37ah cells).
Golf GTE
Disassembly
Useful/Tools used:
- Electric Screwdriver
- Insulation Tape & Duct Tape
- Voltmeter
- Insulated shoes
- Work in the dry obviously
BMS
Battery Modules
Passat GTE
Cooling
Contactors/Pre-Charge
Passat GTE
The Control box contains
- PEC 300A 450VDC fuse
- 1 x Contactor Control Board
| INSERT
Resistor Pic | |||
Golf GTE
The control box contains a
- PEC 250A 450VDC fuse
- Current shunt.
Using Multiple Packs
